All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Tomm on October 28, 2014, 04:58:26 pm
Hey
I have a mk5 gt tdi dsg. The car sometimes jerks a little bit when I’m driving. Also when the car is cold in the morning and i have it in drive whilst stationary at the lights the car jerks and sometimes cuts off, However when i put the car in neutral its fine. Its starting jerking a little bit when I’m driving even when the car has heated up. Something aint right :(
Does anyone know what this problem could be?
An oil change and a reset would be a good starting point these post will help.
http://forums.tdiclub.com/showthread.php?t=169356&highlight=DSG+DIY
http://www.mk5golfgti.co.uk/forum/index.php/topic,24158.0.html
If those fail then it gets expensive!
Thanks! hope the reset works. What if the reset doesn't work, what do you think it could be ? worried !
Maybe the DSG oil needs changing (Depending when it was last done)
If that doesnt solve it, then could be mechatronic unit on its way out
Forgot to mention, i had the dsg serviced quite recently. Il see if this reset helps
Vw can diagnose it for £65.
I'm going to reset the dsg and hope that will solve it , if it doesn't it will have to go to the dealers for a check.
