		All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Dalejones on November 06, 2014, 06:27:24 pm
				I have been told that the textured ones can't be painted, what has everyone else done to have there's colour coded, the r32 one are smooth and come primed but don't really want to fork out for new ones, any suggestions??
				Anyone??
				the textured ones can be painted they just need high build primer and sanding
 who told you they can't be painted?
				I had mine painted and they were the textured ones. Any decent bodyshop should have no issues doing them.
				Will they need to be rubbed down flat first?
				they will need to be rubbed down to take the texture away, they will they be primed and finished with paint. It can be done loads of people have had it done including myself. Its best to get a professional to do it though.
				Can someone write a step for step guide for me so I can prep them myself inc grades of sandpaper? Il prep them myself
				Not really necessary to remove the texturing - I did a mk4 4-motion front spoiler.
 Degrease / clean thoroughly
 Plastic primer
 Hi-build primer - multiple coats to suit (light sand inbetween coats to remove imperfections if necesasry)
 Top coat
 Lacquer
 (depends on how much time / space you have and the quality of finish you want!)
				Ok il give this a go!
				you want to be using a grit around 240 or 320 by hand, then use adhesion promotor, high build primer, flat that smooth with 800 by hand ready for paint,
 using a da machine your going to need different grades of paper
 jake
				had my to the body shop week ago and they are completly smooth and nice looking  :happy2: as i say you pay for the quality   :pomppomp:
				Out of interest, is the Ed30 bumper and spoiler kit any diferent apart from being smooooot and painted?
				The Ed. 30 front spoiler is a bit bigger and gives a more sporty look. The rear spoiler has a different shape, but basically the same size.
				What should it roughly cost at a bodyshop out of interest?
 N,,
				they can be painted just need sanding otherwise paint will peel off had 2 skirts and bumper done for £120
 Crikey! That's very reasonable - i thought would be more expensive tbh  :notworthy:
