All Things Mk5 => Mk5 General Area => Topic started by: Garth on November 14, 2009, 10:44:34 am
Title: Windows up/down with remote?
Post by: Garth on November 14, 2009, 10:44:34 am
Can anyone please explain the standard functionality of this to me?
I was under the impression that you simply held down on the open/close button and the windows would go up/down as long as you held the button down (how it worked on my BMW).
I cannot get any window functions to work at all on my car using the remote.  :confused:
Title: Re: Windows up/down with remote?
Post by: nwhiteley on November 14, 2009, 10:48:55 am
On my Leon, and GTI before it, i just held down the unlock button to open the windows and the lock button to close them, it takes about 6 seconds for the windows to start opening/closing i think.
Post by: clive_gti on November 14, 2009, 11:17:40 am
Holding the lock button should raise the windows and holding the unlock button should lower them.. does on mine anyway.
Post by: TomB on November 14, 2009, 11:36:15 am
As clive_gti, I hold the lock or unlock button, the LED on the door card flashes 5 or 6 times and the windows start moving.
Post by: stealthwolf on November 14, 2009, 01:26:35 pm
Try putting your key in the lock and then either holding it in the unlock or lock position first. If that works then try your fob.
Post by: neg on November 14, 2009, 05:16:29 pm
It can be turned on/off in vagcom/vcds.
If you have a sunroof this will also close but only once the windows are fully closed.
