All Things Mk5 => Mk5 General Area => Topic started by: em2evol on November 16, 2009, 01:10:05 pm
Title: Just got mine back
Post by: em2evol on November 16, 2009, 01:10:05 pm
Just got my car back from a service and cambelt change / new brakes etc (expensive!) and the guy who dropped my car back goes "and I've put £20 of fuel in it for you" I said "95ron or 99?" and he goes "95..." I was like "NOOOOOOOOOOOOO!"   :sad1: The tank is half full now with 95 ron fuel, is it best to fill it to the top with 99 or wait until I've used this crappy stuff up before putting a good lot in?
Title: Re: Just got mine back
Post by: JPC on November 16, 2009, 01:11:31 pm
id run it on the 95 until its gone.
theres no point mixing 99 with it.
by the time your 1/4 down in a full tank of 99 you'll be right! ;)
Post by: CarrG on November 16, 2009, 01:23:17 pm
Don't worry it's not going to kill it!  :smiley:
Post by: cuprak1 on November 16, 2009, 01:29:39 pm
i put £45 of v power in mine last night only to realise i have a flat tyre.. what a waste lol... ill let it mature in my petrol tank for a few days hahaha
Post by: CarrG on November 16, 2009, 01:35:41 pm
Doesn't it go off afer time?
Post by: animal on November 16, 2009, 01:42:12 pm
Yes but it takes ages to break down to point where you'd actually notice.
Personally, I'd brim it with 99 if you're that bothered but ETTO, it wont do any harm. Out of interest, how bad is it running on 95?
Post by: cuprak1 on November 16, 2009, 01:55:52 pm
you mean v power has an expiry date  :confused:
Post by: CarrG on November 16, 2009, 02:07:14 pm
Lol. It losses it's RON rating over time. Not sure what the timescale is tho! Months i'd guess.
Post by: em2evol on November 16, 2009, 02:10:42 pm
Well I've just taken it for a spin on my lunch break and I was worried that they may have wiped the Revo off it but perhaps it's just becuase it's got the wrong fuel in it that it's not running at full potential? Still wheel spins in 2nd, but only just, whereas before it was everytime and easily... I'm hoping it's just the fuel.
Also, having new brakes (which I conveniently forgot about on my little spin a minute ago) means I have to be careful on the braking front for a while doesn't it? How careful and for how long? And will be having forgotten about hard braking for the 15 mins I was out be bad?!   :confused:
Post by: revo carl on November 16, 2009, 03:23:26 pm
don't worry! if they have..... just pop back to your dealer and get it reflashed :)
Post by: RedRobin on November 16, 2009, 03:29:03 pm
Disconnecting the battery is what usually resets your ECU so that your Revo remap is 'switched off'.
Some Revo dealers charge to reflash but only a nominal sum like £25 to cover their time.
Post by: em2evol on November 16, 2009, 04:15:12 pm
 :grin: I do worry an awful lot about my lovely GTI, I just want everything to be dandy! I was annoyed even that the fleet guy who dropped my car off put his briefcase on the passenger seat! THAT DOES NOT HAPPEN!  :grin:
Post by: animal on November 16, 2009, 04:26:28 pm
The Revo map is kept is volatile memory? Fuel trim and stuff is normally kept in KAM and is what gets wiped when you disconnect the power (ECU reset) but the base engine management software is normally hard coded to the ECU (EEPROM) - is this really the case? The car reverts to the OE map if power to the ECU is cut?
EM2EVOL - Give your brakes a couple of hundred miles to bed in. Don't baby them though, just brake normally and avoid hard applications.
Post by: stealthwolf on November 16, 2009, 04:27:15 pm
The GTI haz a sensor to detect whether 95/98 ron is used and adjusts things accordingly so it is less powerful on 95 ron. At least, that's what I've picked up from here.
Also, why did he need to fill it with petrol? Did he go joyriding?
Post by: animal on November 16, 2009, 04:28:49 pm
Yes all petrol does... It's quite volatile stuff. Have you ever noticed how fast in evaporates when you spill it?
Post by: Hedge on November 16, 2009, 04:44:11 pm
From when I had REVO if you disconnect the battery you end up with the non-performance settings of B0 T0 F0 plus any adaptions will be out the window.
Post by: em2evol on November 16, 2009, 04:58:49 pm
Hmm that's interesting about the sensor... very clever!
He had to put petrol in it because I gave them the car on Thurs with no fuel (stupid of me I know but they could've put 98/99 in!) and the place is 70 miles away from me (it's the boss's brother's place and he was so kind as to let me have a good discount) so there we have it...  :P
Post by: RedRobin on November 16, 2009, 06:35:00 pm
....That's how I understand it too.
After a battery disconnection and reconnection, if you have a Revo switch box you can just reload the Revo settings as you last had them.
Post by: revo carl on November 17, 2009, 10:23:40 am
Wrong;
these are knock sensors and will detect high levels of knock (pre detonation!) and reduce timing/load requests, if running switchable software it's always advisable to switch the car to the appropriate fuel setting to stop this happening as the vehicle will take a long time to adapt out of this so the car will feel down on power for a long period after switching back to good fuel!
Lol! As far as I know there have been no updates to the GTI yet so there would be no reason for your dealer to re-flash the ECU but if you’re worried you can just verify that your software is still present with your REVO dealer.
These cars (MED17 ECU) do not switch to stock with a battery disconnect IIRC…… but I will check for you all!  :smiley:
Post by: em2evol on November 17, 2009, 11:47:36 am
Wrong;
A long period?   :confused:  How long is long? My car felt proper sluggish compared to normal this morn  :sad1:
Post by: animal on November 17, 2009, 11:50:01 am
Wrong;
Also worth noting that knock sensors are far from unique to the GTi - it's just down to how adaptable the car's ECU is.
Carl, confirmation on the loss of Revo settings after a battery disconnect would be greatly appreciated. As I said, I know fuel trim, ignition timing etc are stored in KAM but actual Revo settings too?
Post by: animal on November 17, 2009, 11:53:15 am
Wrong;
A good few miles I would've thought, although I can't really comment on VW ECU's - This is when a battery disconnect for 30 mins would help as it clears all the stored values and allows the ECU to start again.
Off to text my friendly VAG calibration engineer...
Post by: SteveP on November 17, 2009, 12:15:54 pm
Mine 100% loses the Revo settings after every battery disconnect.
Post by: animal on November 17, 2009, 12:19:17 pm
Fair enough, not ideal though? Is this only a Revo thing or is it something to do with VW ECUs?
Post by: RedRobin on November 17, 2009, 05:13:18 pm
....So does mine (GTI not Ed30) but the other question is whether the original Revo T/B/F settings are restored when using the standard Revo Select to switch back to Performance map afterwards  - Mine does.
Post by: revo carl on November 18, 2009, 02:17:04 pm
The MED9 ECU's (MK5 2.0t etc) will switch to stock when the battery is disconnected yes, the newer cars fitted with the MED17 ECU (MK6, Rocco etc) will not switch to stock with a battery disconnect
the reason we did this with the MED9 ECU was it was something that a lot of our customers asked for at the time and thus it was set in place, we have not been asked to do this with the MED17 ECU and thus haven't  :wink:
Doesn’t need to be 30mins, 30seconds will do it on these ECU's
Post by: RedRobin on November 18, 2009, 02:56:34 pm
Thanks for clearing that up, Carl  :happy2:
After a battery disconnect on a MED9 ECU, when one uses a standard Revo Select switch to re-'load' the Performance map settings, I assume the ECU must have 'remembered' the most recent T/B/F values as previously to the battery disconnect.
Post by: Peskarik on November 18, 2009, 03:57:51 pm
yep, that's it, your car will explode now...  :stupid:
Post by: animal on November 18, 2009, 04:07:59 pm
Intrigued to know why so many customers requested the map revert to standard after a battery disconnect though?
Post by: stealthwolf on November 18, 2009, 05:41:34 pm
I knew it was something like this but couldn't remember the details. Thanks  :happy2:
Post by: Lyons on November 18, 2009, 06:07:49 pm
I assume 95 is sufficient for standard GTi's?
Post by: Top Cat on November 18, 2009, 06:10:45 pm
Nope! It is designed to run best on the higher octane.
Also its another false economy. It costs more at the pump but you get better fuel economy from the higher octane. ( and more fun. )
Post by: stealthwolf on November 18, 2009, 06:15:21 pm
The car will run on 95, but as stated above, the car will run slower and with worse mpg. Use 98+ RON for the best effect. Most forumites here use either V-power or Tesco's 99-RON fuel.
Post by: Lyons on November 18, 2009, 09:30:24 pm
But it wont necessarily do it harm, just wont get the best from it?
Post by: revo carl on November 19, 2009, 11:06:20 am
correct
Post by: Phil Mcavity on November 19, 2009, 09:18:29 pm
But if your running a map, high octane is 1st on the menu. Standard stock car , 95 ron is ok, but as a last resort.
