All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Vandyer on November 23, 2014, 04:55:44 pm
Title: RNS510 how do I find out if it's Rev a, b c etc and firmware?
Post by: Vandyer on November 23, 2014, 04:55:44 pm
I've search on the forum and other places but can't work out how I find out what firmware and revision I have
Do I need to physically remove the unit?
I've held down the 'setup' button for 5 seconds but all i get is 'AM' and 'FM', nothing else
It looks like the maps are old- it's still showing roundabout on the A1 near Grantham!
Title: Re: RNS510 how do I dint out if it's Rev a, b c etc and firmware?
Post by: RetroRaz on November 23, 2014, 04:59:16 pm
You need to enable the secret menu using vcds and then check it
Post by: Vandyer on November 24, 2014, 09:40:37 am
Ah I see. VCDS.....Very Costly Dangerous Solution?
Sounds like strip to an expert.....thought it was something I could do
Post by: RetroRaz on November 24, 2014, 09:57:28 am
Where abouts are you based?  We have a VCDS register list on here. Anyone near you may be able to help you.
http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html
Title: Re: RNS510 how do I find out if it's Rev a, b c etc and firmware?
Post by: Vandyer on November 24, 2014, 03:13:55 pm
I'm in Harrogate
More thorough research and I realised I needed to keep the setup button pressed for longer....and it works.....
Thanks for advice
