All Things Mk5 => How to Guides / Troubleshooting => Topic started by: GTIEagles on November 25, 2014, 10:27:00 pm
Title: Clutch very occasionally sticking halfway down
Post by: GTIEagles on November 25, 2014, 10:27:00 pm
On Monday morning I let my car defrost for 5-10 mins. I went to drive off and the clutch was stuck halfway down. I pulled it up with my foot and it was fine after that. The same thing happened today and it was fine again after I pulled it up. Any ideas?
Title: Re: Clutch very occasionally sticking halfway down
Post by: howie1987 on November 25, 2014, 11:45:42 pm
Mine does that aswell. I had a new clutch fitted and it still does it. Audi said it was fine so god knows.
It is still fully in gear though so it doesn't affect it but its just annoying.
Good to see if anyone has a fix.
Post by: xjay1337 on November 26, 2014, 12:24:52 am
Sounds like your slave cylinder is on the way out. They're about £50. Needs bleeding afterwards.
Post by: howie1987 on November 26, 2014, 03:30:22 am
Mine already had slave cylinder done when i done the clutch. The peddle feels fine most of the time and when it does stick a bit its far enough up that gear is fully engaged. Its a weird one it feels more like somthing to do with the peddle.
Post by: GTIEagles on November 26, 2014, 09:31:07 am
Thanks for the info, I suspected it might be the slave cylinder. I have heard it's a big job on a MK5 Golf? I think I will try and get the clutch bled first as my first port of call and pray it cures it! I can live with it if it only does it every now and then but if it happens more frequently it's gonna have to be fixed!
Post by: xjay1337 on November 26, 2014, 11:33:13 am
Never done one on a 6 speed but a 5 speed is a piece of piss. Airbox off replace the cylinder from top of gearbox and rebleed.
Post by: GrayMK5GTI on November 26, 2014, 12:57:16 pm
Slave is in the gearbox casing on a 6 speed. May as well replace the clutch while your at it  :sad1:
Post by: xjay1337 on November 26, 2014, 01:02:15 pm
That's very bad times ;(
Post by: GTIEagles on November 26, 2014, 01:53:14 pm
That sucks! Would the DMF be worth replacing too then? So far so good today, I wonder what makes it an intermittant fault??
Post by: doylebros on November 26, 2014, 06:01:12 pm
In the link below
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=7&grf=072125409&bf=72125&hgug=721&ug=21&parent_id=2348357&detail_id=2348476
item 30 - (pipe and diaphragm) has been known to cause a similar issue where you need to pull the clutch pedal back up (part number pending your engine type)!
Post by: GTIEagles on November 27, 2014, 09:31:17 am
In the link below
Thanks mate, I will bear this in mind if the bleed doesn't fix it. This is the 2nd day with no problems, very odd...
Post by: Gasman on November 28, 2014, 06:42:36 pm
Mines doing this a lot lately but only when it's cold. Once it warms up its fine.  my master cylinder was replaced a couple of years ago so I don't think it's that I'm thinking it's the slave cylinder.
Post by: howie1987 on November 28, 2014, 07:42:49 pm
I think that would affect the brakes though would it not?
Am going to price that pipe (above) see how that goes.
Mine hadn't done it for a couple of weeks then it done it twice today. It isn't that big a deal i don't think, aslong it doesn't damage anything else.
Post by: GTIEagles on November 29, 2014, 07:13:41 pm
I was sat in the car earlier and I managed to get the clutch to stick again. This time the engine wasn't running and as I pumping the clutch it started to stick and each successive pump it stuck further down. I then turned the engine on to see if it would release the clutch but it stayed down and when I tried to select a gear I
wouldn't budge. Any ideas? If I pulled it up again it sprang back to normal.
Post by: vRSAlex on November 29, 2014, 08:01:34 pm
Give it a bleed first. As it used brake fluid, ideally it should be changed every couple of years. Hardly anyone does change it though.
Post by: GTIEagles on July 02, 2015, 02:02:41 pm
I just wanted to open this thread up again to get opinions.
The sticking clutch appears to have completely disappeared. I haven't replaced any part or even bled it. I would say that since early this year it's gone and never come back  :surprised:
How is this even possible? The only thing I can think is when I bought the car it had been left standing for a couple of months so maybe there was moisture in the system or an air bubble somehow formed which has eventually worked it's way out?!
I've probably just completely jinxed it now!
What do you think guys?
Post by: ady-uk on July 05, 2015, 03:04:49 pm
I think its more to do with the fact, were in the middle of summer.
Wait till the middle of November and then you'll be cursing it again :(
Mine only did it for the first few miles, on cold mornings.
(can't tell you the problem, as I've not looked at mine yet either)
Post by: GTIEagles on July 07, 2015, 08:41:13 am
I thought the same too but it actually started unsticking probably late Jan so pretty much the coldest time of the year. Time will tell, I hope it stays as it is though  :grin:
