All Things Mk5 => Mk5 General Area => Topic started by: Aparoon on November 17, 2009, 10:31:50 am
I have a real urge to buy the new 'd' revision dv, don't know why just determined to buy one :stupid:
I have taken the original out this morning to check and there are not tares, it seems fine... Am I going to get any benefit from replacing it with the new one or am I just buying for the sake of it?
I've tried the search but can't find a definate answer :rolleye:
Thanks in advance :happy2:
I changed mine. Nothing wrong with the old one when i took it off and i felt like i'd wasted money as there is no difference.
Guess i just did it to be on the safe side.
x2
X 3, although it was really stretched.
I guess you're just removing a weak link for peace of mind - it's not like its expensive.
Is the Forge one worth the money or is the D revision adequate and more reliable that previous versions? Can it hold boost ok on a remapped car?
The D is completely different. A Forge style piston, rather than a diagphram but with electronic movement, rather than the Forge vacuum.
Basically VW copied the aftermarket. I don't know of one failing yet... but I think with big boost, the likes of Forge may be better???
No probs on my stage2 KO3 so far.
Na don't bother with Forge the revison D copes fine with 360hp at a fraction of the price.
Good to know - thanks!
how much is the newest dv? part number anyone?
£45 del. I'll get the part # later. :happy2:
Part No. 06H 145 710 D
im still on one of the old revisions and its fine even with all the boost and naughty'ness i get up to in my car.. i suppose peice of mind is the only thing.
Part number saved. ill see how much i can get them for . cheers
Well I guess i'm not on my own. I am gonna order a new DV tommorow, even though mine is prob ok. Seems a few of you have done the same, so why not!
Can anyone confirm that the latest one is 06H 145 710 D ?
Thanks :drinking:
Monte - as above you have the right part number :happy2:
Do these fit normal k03 GTI's or are the ed 30 specific?
They fit both iirc :happy2:
if your going to the trouble of changing it , i would go with the forge one , its a doddle to fit on the ed30 too :happy2:
...although the forge one needs extra maintenance and regular checks. im going to stick with my original one until i get a leak or tear, so far its been fine, when i do get a problameo i will be going rev D for 40 spondoolies :smiley:
