All Things Mk5 => Mk5 General Area => Topic started by: Jkingti on December 10, 2014, 01:57:24 am
Hi guys I'm thinking of putting bwa engine into me 05 mk5 Gti me original engine code is Axx will the bwa work??
yes, without any issues, straight swap :happy2:
Do I need to change ecu or anything? So the bwa definitely goes in and I won't have any problem trying to get it starting? Do I not need loom ecu or anything considering it is a diff engine code? Have you done this before? Thanks for your reply
Only difference is the compression ratio, so no need to change anything but the engine.
I am running a cupra 245bhp BWJ engine in my AXX GTI with AXX ECU, to establish my credentials
That's great thanks for your help! Do I need to swap anything from my Axx engine into the bwa as in injectors or anything? Can u send your email address as it would be great if I could get some more info from you. Thanks very much
all but compression ratio is the same
Do I need to change crank sensor from my engine map sensor or anythin or just plug and play? I've heard I need to change fuel lines as the lines to my hpfp one is a banjo bolt and on the bwa engine the fuel line to hpfp is a hose
No
hpfp is diff
hpfp is diff
Use your old HPFP if you like, only the connector is different then (banjo instead of later connection). The rest of it - mounting, piston, outlet & capability are all the same :happy2:
Is all wiring the same also the same? I have sourced a bwa engine but the lad said some wiring may have to be relocated? Is this true? Thanks for your reply much appreciated
can I ask why you want to change to the BWA ?
Less susceptible to cam chain and cam follower problems
I thought they was all the same though? apart from compression rating
Different cam, different Pistons, probably some other tweaks elsewhere. . .
Different engine code signifies differences. .
fair enough :happy2:
I'm finding it hard to get axx engine over here so bwa is most common available? Has anyone put a bwa in place of Axx and can give me some info
Just wondering if the axx Bwa swap worked as have mine to do cheers guys
