All Things Mk5 => Mk5 General Area => Topic started by: flashp on December 20, 2014, 07:57:04 am
I wanted to share an experience I had in the very early days of ownership of my Pirelli which I thought I had been put to rest. That was an incorrect assumption, a trackday this month at Goodwood proved this.
Not long after I bought the vehicle I tried to fit my winter wheels I had at the time. In order to get the bolts undone I had to resort to using an extension bar that was in the order 1.5m long. Even with this it took me around 4 hours to get the job done.
Once done, on refitting the bolts it was noticed that a good deal of torque was required to even screw the bolts back down before even correctly torquing them. In the photo you can see the level of distortion to the bolt profile and thread pitch:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi326.photobucket.com%2Falbums%2Fk438%2Fflashp%2FP1000381cropped_zps0576e99f.jpg&hash=446e0ada492f4005394f12943f5f7af46ba7ee20)
Peter Cooper replaced the bolts under warranty without hesitation. They also confirmed that, according to their servicing policies, routine servicing does not require them to remove the road wheels unless pad replacement is required or other specific repairs are required. Brake bleeding is also completed with wheels in place. What with this and the general propensity for the use of air powered tools it's clear to see how this can happen. Air tools may also prevent the issue from being noticed and exacerbate the problem.
I also had to clear the hub threads with a correctly sized and lubricated tap (M14x1.5mm) and while doing this the amount of metal that was removed was considerable but I continued and all was well for while. Until this recent trackday. Being good practice to do so, and with the new vibrations experienced (another issue which turned out to be pad pick up), I set about checking torque on wheel bolts and one of the bolts stripped the hub threads and damaged it's own. On inspection it was evident that the other front hub also required replacing, all bolts were too slack in their bolt holes. The rears were not bad enough to warrant replacement. It was an expensive repair, and one that should not have been required given the root cause.
Had I been more aware of possible complications at the time I would have pushed Peter Cooper to inspect/replace the hubs while under warranty.
In fairness to the Shirley branch they did say they may consider adding the removal and replacement of wheels periodically to servicing programs to prevent this from happening again. Whether or not this was implemented I don't know.
It's still quite a rare issue, but I have seen it a few times over the years.
Have you had to now change all four hubs, or just the fronts?
Just the fronts. The rears were nowhere near as badly corroded.
I assume you never rotate your tyres?
Mine has been dealers its whole life and mine were fine when bought it!
Although i must add that its never going to dealers again as now all work and services are done by myself not spotty teenage grease monkeys!
Must agree though it's definitely something worth checking, whenever I purchase a car I usually remove all wheels and apply a dab of copper slip to all bolts and hub faces etc to avoid nightmare at side of road if ever get puncture :sick: always carry a large torque wrench too
I do indeed. Particularly as I'm on and off track fairly regularly. Can't speak for the previous owners though.
I have had issues with my car after main dealer servicing. When I went to remove the wheels to fit my 345mm OEM brake upgrade, I had to also use an extension bar to remove the over-tightened wheel bolts. I had the VW main dealer replace brake discs and pads a year before so easily knew it was them who over tightened the bolts.
I'm in the mind set that when I upgrade my brakes again, I shall replace the wheel bolts as well and may even ask AKS Tuning to inspect the car fully while it's in there for a full SuperPro bushes and ARB upgrade.
Am I having a brain fart or is there a simple, common practice I've not done often enough?
I can't rotate front to back lately due to the balancing having to be done differently on the fronts to ensure clearance with the calipers
I work for a main dealer and we remove the wheels on a service..
Little point in taking wheels off to service a car...
On some models it made access to the oil filter and sump easier, but on mk5 Golfs there's little need unless you're unable to jack the car up very high.
Shh, he's a spy! :signLOL:
Grease hub faces otherwise good luck when your lying on road trying to kick the wheel off the hub as its been on there for a few years especilally on rear where tyres are rarely changed etc
Sorry but this should definately be part of a major service at any garage let alone a main dealers :ashamed:
I've worked for a lot of main dealers in the past and it's not common practice to move wheels on a service unless you need too, also every car ive ever service that ive had to remove the wheels for whatever reason get torqued to the correct spec but this is not done by everyone. The manufacture writes the service sheets out so you only do what's on the sheet , but I agree all wheels should be removed on all services and the hubs should be greased so incase of a punture they can be removed easy not trying the kick the wheels off at the side of the road !!!
perfectly said, those who think it's ok not to remove the wheels as part of a service are the ones who get the problems. it's dumb and just lazy.
Seems more common than I thought I took my car to vw for service cambelt etc, then had a slow puncture the poor bloke at the tyre place nearly crapped himself trying to get the wheel off,
Yes it's FAIRLY common to just windy-gun bolts up.
Although most places I find their air guns are not set up to pound the bolt in, they just do them tight-ish and still usually get a half turn or so with a torque wrench before they hid 110ft lb or whatever you decice to do them to.
Are you sure your vibrations from your brakes didn't mess up the threads?
In my earlier post I showed the photo of the bolt and explained the circumstances. The photo was taken not long after I got the car. The vibration occurred a couple of weeks ago. It's equally possible that the damage may have been contributed to by the force required to remove the bolts.
Had my springs done at an indy. Half the bolts so tight it broke my extension bar so i had to breaker bar them off. Some wheel nuts so loose that I could feel play with just my fingers. So bloody angry Im going to complain. Windy gun job i suspect. I thought I had a bit of a wobble on breaking or going round corners but thought it was my imagination. Done nearly 600 miles like that until I changed my wheels. Could have lost any wheel at any time :fighting: :mad:
My motto now definitely is if you want piece of mind only person you can trust is yourself (sorry to the proper mechanics who do do a proper job.) . When your car is your pride and joy, and you place the lives of yourself, your family, friends etc into your car, wheels hanging loosely is unforgivable imo.
Torque wrench is your friend and tighten opposite nuts to make sure wheel is square on the hub. Also lubricate the hub and nuts too to stop them seizing.
Rant over
