All Things Mk5 => Mk5 General Area => Topic started by: NDGTI on December 20, 2014, 02:59:07 pm
Hi all
where can i get a 2014 update for my 2005 gti satnav /?
not paying VWs ridiculous prices
Are you asking for a map update for your MFD2?
If it's a DVD version you can get 2015 maps from www.gpsunderground.com.
Which satnav is it?
thanks, yes i want update for my MFD2
so if i was to buy disc, does it just slide into mfd2 consul and update itself ?
For the maps I think you only need to burn it and insert it. If all works fine you don't need to do anything else. If not, you might need to make sure your HU is unblocked. Read the DIY manual available in that site I mentioned above and update the radio to the latest firmware available and unblock it to accept the DVD with the maps.
excellent........ thanks Shoduchi
silly question, but how do i know if mine is a DVD version or CD ?
AFAIK the mfd is cd and the mfd2 is dvd. It should tell you in your manual which it is :happy2:
There are 2 versions of the MFD2. The earlier read only CD and after that it appeared a DVD version. The colour of the buttons differ. The manual should tell which it is. :wink:
Black buttons=cd version
Silver buttons=dvd version
Non genuine cd/doovd's will make the maps run slightly slower, not much mind
