All Things Mk5 => Mk5 General Area => Topic started by: omeydz on December 27, 2014, 10:26:24 pm
Title: Plastidipped wheels care and cleaning
Post by: omeydz on December 27, 2014, 10:26:24 pm
Hi all! Happy xmas and 2015!
Got merry with the plastidip and got a stealthy set of ed35 black alloys.
Look ace after 4 cans and some time n elbow grease. How best to make it keep its finish good for long as possible and how to wash it safely? No jet washing i presume?
Many thanks
Title: Re: Plastidipped wheels care and cleaning
Post by: ROH ECHT on December 28, 2014, 03:42:44 am
Definitely do not use pressure....my front end bits always peeled. Got tired of redo-ing them. I just painted my wheels due to lack of confidence in plasti-dip. I would say use a diluted pressure washer cleaner in a spray bottle to pre-soak the wheels and gently rinse.
Post by: howie1987 on December 28, 2014, 03:44:31 am
Hi m8. You can jet wash them. But just keep it back a bit. Use non acid shampoo and the autoglym rubber and vinyl care after that. Every 4 weeks or sooner. Thats what i do with my car that has been plastidipped.
Post by: omeydz on December 28, 2014, 01:04:58 pm
Ah right. I think pressure wash is totally out the question.
Fitting them thismorning i had to redo 2 areas where it peeled of while handling the wheels. Gotta be so darn careful im thinking its going to be tough to keep them good. And at 10 plus a can its a bit of a false economy long term :P
Post by: ROH ECHT on December 28, 2014, 08:32:14 pm
These 2 bits always peeled with 3 coats...
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1205.photobucket.com%2Falbums%2Fbb434%2Frohecht%2F003-3.jpg&hash=5305118ad669f01c7cdcaea7168ca169f6ba61c6) (http://s1205.photobucket.com/user/rohecht/media/003-3.jpg.html)
even with being careful of the nozzle distance of my washer. That being said, I believe with wheels one should cover both inside and out with plasti-dip to eliminate any ends or edges of the product other than at the outer rim. Also...it has been said to use 5 coats on wheels. You still need to be careful because if anything contacts or grabs onto the surface...it will peel.
My newly self-painted wheels however... :drinking:
I used flat blk. engine (high-temp and fluid resistant) paint that was 1/3 the cost of p-dip, but you cannot peel it off if one should change their mind.
I would just need to respray.  :happy2:
Post by: omeydz on December 29, 2014, 09:51:23 am
Thanks a lot! Will tread/drive carefully and see how long it lasts.
Paint may be on the cards sooner or later. Definitely bored of bright silver coloured wheels.
Post by: alexharvey on December 29, 2014, 10:36:22 pm
you need loads coats with plasti dip mine lasted ages when i dipped them
i used normal alloy wheel cleaner and a brush always came up well and never messed them up
also depends on the dip u use if genuine or not
always jet washed mine no probs too
Post by: ROH ECHT on December 29, 2014, 11:45:31 pm
↑ Right....heavy on the coats seems appropriate  :drinking:
Post by: omeydz on December 30, 2014, 10:24:32 am
I did 1 can a wheel. Its Hyperlex German stuff 450ml cans.
Not worth shelling out another £50 for 4 cans imo. Rather paint them for that money!  :signLOL:
Post by: ROH ECHT on December 30, 2014, 07:05:44 pm
That was my thoughts, exactly, when I decided paint was the way to go. Luckily I had the experience of the peeling and wanted no part of it. Plus, it's not like I was ever going to change my mind on the color.  :drinking:
Post by: omeydz on December 30, 2014, 08:54:16 pm
Well i guess plastidip is a good reversible way to test how a colour looks on your car before you get it permanently in paint.
On a lesser note I kerbed my wheel today and I wanted to cry! Plastidip lost vs the kerb. Came home and sprayed the areas over in plastidip n felt a bit better. pretty well hidden but you can see the corners of the peel area up close. I should use my self parking system more lol. In fairness wasnt used to how much the wheels stick out.
