All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: RetroRaz on January 01, 2015, 03:51:31 pm
Title: Which Bluetooth Loom
Post by: RetroRaz on January 01, 2015, 03:51:31 pm
Hi everyone,
Im looking to sell off my Fiscon Basic Plus as its not working properly with my RNS510, and looking to get a 5N0035730B unit.
I want to know which loom to get as I would like to add an AUX in cable soon at some point and don't have an MDI kit at the moment.
can anyone advise which loom to get?
http://www.carsystems.pl/wiring-harness,c79.html?order=c&dir=d
Can i fit one of these to the loom?
http://www.ebay.co.uk/itm/VW-GOLF-MK5-AUX-IN-INPUT-ADAPTER-INTERFACE-CABLE-LEAD-RCD210-RCD310-RC510-IPOD-/361010973352?pt=UK_In_Car_Technology&hash=item540dee4aa8
Title: Re: Which Bluetooth Loom
Post by: Degudodger on January 01, 2015, 04:05:36 pm
I fitted this to my old Mk5 - simple plug and play with the AUX input located behind the gear stick.
http://www.ebay.co.uk/itm/Switch-Plug-AUX-Cable-For-VW-Volkswagen-GOLF-JETTA-Sagitar-RCD510-300-Cuddly-/201162109859?pt=UK_In_Car_Technology&hash=item2ed63233a3 (http://www.ebay.co.uk/itm/Switch-Plug-AUX-Cable-For-VW-Volkswagen-GOLF-JETTA-Sagitar-RCD510-300-Cuddly-/201162109859?pt=UK_In_Car_Technology&hash=item2ed63233a3)
Post by: RetroRaz on January 01, 2015, 04:18:41 pm
cheers buddy.
does the white connector go straight into the factory wiring loom behind the CD player? no need for an MDI kit?
Post by: Degudodger on January 01, 2015, 04:22:48 pm
Its as easy as inserting the plug into the Quadlock that plugs into the back of the stereo and away you go :)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi184.photobucket.com%2Falbums%2Fx211%2Fdegudodger%2FKL07PEP%2F5B0D7A93-22BE-47F1-8400-1818E72FAA3D_zpsrukkmkln.jpg&hash=da333dc3b03c7efbf8ad4892d1bd5b975b297393)
Post by: RetroRaz on January 01, 2015, 04:31:09 pm
awesome! going to order this now. I take it I can just use a standard bluetooth loom then
Post by: Degudodger on January 01, 2015, 04:32:35 pm
Drop Eddie-NL a line as he normally has BT looms at damn good prices :)
Post by: Eddie-NL on January 01, 2015, 07:45:14 pm
I can supply Pnp Bluetooth loom with Euro spec Microphone (Not Chinese)
Post by: RetroRaz on January 02, 2015, 12:57:05 am
Ed ill send you a text tomorrow.  Cheers
Post by: usmangti on February 04, 2015, 11:57:15 pm
@Degudodger (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=2485) @vw55raz (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=6494) quick question if you can help please, which end goes into the quad lock? The white end? I'm planning to use it with a rcd310, should the same fitting as the rcd510 right?
Thanks Usman
Post by: RetroRaz on February 05, 2015, 12:44:19 am
yes the white end goes to the quadlock. same fitting.
Post by: usmangti on February 05, 2015, 01:13:46 am
Thanks @vw55raz (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=6494)  :happy2:
Post by: usmangti on February 05, 2015, 01:37:56 am
Just bought one showimg estimated delivery between 27th feb and 10th march! How long did your delivery take?
Post by: Cossie Killer on February 05, 2015, 07:44:35 am
About 10 working days for me
Post by: usmangti on February 05, 2015, 10:46:44 am
cool thats not to bad then :happy2:
Post by: Cossie Killer on February 07, 2015, 09:58:38 pm
Well i plugged mine in today.... And nothing :(
It only goes in one way, so its either duff or its the loom.
Post by: usmangti on February 07, 2015, 10:18:04 pm
What stereo have u tried it with?
Post by: Cossie Killer on February 07, 2015, 10:46:00 pm
RCD310.... Ive also tried it with the MDI unplugged
Post by: Cossie Killer on February 07, 2015, 10:46:56 pm
It shows AUX on the screen but no sound.
Post by: usmangti on February 07, 2015, 11:08:26 pm
Oh well that's crap as ill be using it with a rcd310 too. I have a rcd510 also and I remember seeing an aux level in the settings so will try that unit also If I have no luck with the 310. Hopefully its something minor someone could point out.
Post by: Cossie Killer on February 07, 2015, 11:59:51 pm
Will have another play tomorrow
Post by: usmangti on February 09, 2015, 11:31:24 am
@Cossie Killer (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=11234)  did you manage to get the aux working?
Post by: Cossie Killer on February 09, 2015, 11:34:45 am
Fraid not, checked the settings and the volume was at its lowest setting, so changed it but no difference...
Only thing I didnt check was the connector in the back of the switch, maybe its the wrong way around  :confused:
Post by: usmangti on February 10, 2015, 10:10:11 am
Had a flick through the settings on my rcd310 this morning, there seems to be 2 AUX options. 1 is level and the other is either on or off. You more than likely have already done this but to check have you switched it on from here?
Post by: Cossie Killer on February 10, 2015, 10:14:40 am
Yes, tried that. I want to check the switch again and try plugging in a android phone but if that doesnt work, its either the switch or the loom.
