All Things Mk5 => How to Guides / Troubleshooting => Topic started by: big eck on January 06, 2015, 09:56:13 pm
Title: Rear stone guard removal *anyone know how???
Post by: big eck on January 06, 2015, 09:56:13 pm
Evenin guys.
I have a problem with my car. The rear passenger stone guard has worked its way loose and is now rattling about really loudly and scrapes like mad on the disc when I drive. As you can imagine it bloody loud when driving, so loud in fact that people can hear it from 50yrds away.
I've looked for the part online but I can't find it either.
Does anyone know how it comes off?? I've had a look at it from underneath and it looks like I need to remove the caliper and disc. Is there anything else I've missed???
The car itself is the mk2 Leon Cupra but it's the same as all mk5 golfs I think??
Title: Re: Rear stone guard removal *anyone know how???
Post by: jason_rmh on January 06, 2015, 10:19:25 pm
You need to remove Caliper and disc. This will expose the brake shield. Its held on by 3 torx screws.
Once they're removed you will need to cut part of the shield to get it off the hub.
If you do it right, you can refit it as well. Depends what has made it come loose. Maybe the torx bits have rusted away or come out?
Jas
Post by: big eck on January 06, 2015, 10:25:33 pm
Thanks mate. I've no idea why it's actually come off.
I just need to buy a set of multi spline bits to remove the caliper itself now as the tool kit I bought from halfords didn't come with any :(
Post by: jason_rmh on January 06, 2015, 10:34:51 pm
You need something to cut the shield too, if you need to completely remove it. I used an angle grinder.
Post by: big eck on January 06, 2015, 10:38:32 pm
Hopefully it's just the bolts that have come loose and they need replaced. That way I don't need to chop things up.
Post by: jason_rmh on January 06, 2015, 10:39:38 pm
Here's a pic of it with Caliper removed:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Faf280%2Fboostedrabbit%2FDSCF1522.jpg&hash=d712c0dac075fef1616603b0bbcb1c5ae5cd03e8)
Yours may be rotten.
Jas
Post by: jaffa on January 07, 2015, 12:23:54 am
Chances are it's rusted around the bolts
Mine rusted away completely and started rubbing on the disk so I just took both the rear ones off but I didn't have to do any cutting
All I did was remove the caliper and the disk
It's quite common for them to rust
You can do a temporary fix by sandwiching the bolts with washers but it will need to be replaced or removed at some point
Post by: Lyons on March 06, 2016, 05:42:07 pm
1 of my rear stone guards had managed to work itself loose. Anyone have a DIY for removing the caliper and disk for a complete novice?
Post by: GTI8v on March 06, 2016, 07:10:08 pm
Quite a timely post as I noticed one of mine was rattling yesterday so had a quick look to see what it was this morning.
Without taking the caliper off it looks like the sheild had rotted through on the top bolt. Managed to bend it slightly so it's no longer rattling, but I'm hoping that a suitable sized washer will do the job.
Was looking to change the rear discs and pads shortly anyway so will sort it when they're off.
Post by: jason_rmh on March 07, 2016, 07:25:51 am
To remove it properly I think the hub has to come off. The work around is to cut it to allow it to be manipulated around the hub, after removing the torx screws.
Jas
Post by: Lewo on March 14, 2016, 07:48:26 am
Mine went last week, mate cut the back plate off with tin snips.
Easier than taking caliper off. :smiley:
Post by: Lyons on March 14, 2016, 08:55:58 am
Ended up doing that after I removed the caliper. The disc wouldn't come off past the carrier, so I just abandoned it and got the hack saw out!
I had a look online there and replacements are about £25!!
Post by: Lewo on March 14, 2016, 09:09:42 am
Actually yes he did take caliper off!
Post by: xjay1337 on March 14, 2016, 11:13:36 am
I had this issue on my GTI.
Bolt that held it in place had rusted away so it would wobble.
Post by: akbarirfan on February 17, 2021, 02:14:22 pm
Hi All,
Resurrecting this thread to say that I got my rear guard off by cutting it in half using a hack saw and a bare hacksaw blade (to get greater depth).
Mine was broken at all three fixings so I made a cut towards one of the fixing holes and at the 11 O'clock position when facing the hub.
Hopefully this will be of use - they sure do make a racket!
Post by: pudding on February 19, 2021, 10:27:45 pm
Wait until the discs/pads need replacing, buy a couple of hub bolts, take the hubs off and fit new shields & brakes as a job lot  :happy2:
I would retain the shields as they keep harmful brake dust away from the dampers and bushings.
You will need a big ol' breaker bar to achieve the 180 degree final torque though.
Post by: rich83 on February 19, 2021, 10:49:24 pm
Yep... that 180 is a absolute f*cker! Got video evidence of that  :signLOL:
Post by: pudding on February 19, 2021, 11:19:34 pm
It's an utter swine with regular 1/2" sockets and breaker bars, but swings round easy peasy like butter with the proper VW 3/4" socket and 1M breaker bar  :happy2:
Post by: pudding on April 03, 2021, 12:14:57 pm
Finally got around to doing them yesterday.
Not the most pleasant of jobs  :grin:
(https://live.staticflickr.com/65535/51091066350_8069adbbcb_k.jpg)
