All Things Mk5 => Mk5 General Area => Topic started by: DomBacon on January 10, 2015, 06:59:10 pm
Autotech hpfp or loba hpfp whats everyones views?
See better results with loba?
if your not going big turbo you wont see any benefit having either different.
Just at first autotech had a few failures which put people of.
They always make the same power and flow more than enough for a k04 setup
but since the part has been revised and they seem good now :happy2:
Below 300bhp then the Autotech is fine. Over that and APR or Loba are the better options.
Eventually I'd like to get a bigger turbo and was going for the loba hpfp but just wondering if theres any difference in them or if its just the £200+ price difference!
There is difference yes, but you may be better buying a used Loba pump which will narrow the price difference. They crop up from time to time.
the price difference is because LOBA pumps come complete i.e LOBA internals in a new HPFP and they throw in a new cam follower.
Auto Tech internal are just that. Just internals.
HTH.
chalk and cheese mate,Ry at garage midnight on his big turbo is still running autotech and over 500hp,each to there own
even niki who tunes them says autotech is more than up for the job ! i know many people with over 350bhp myself one of them on that pump.
i got mine from garage midnight :happy2:
I think without both companies providing tech data it is impossible to say autotech<LOBA for HP. Many run the autotech well over 300hp. I had it @ 330 HP initially, and then up to 370HP, and my specified rail pressure in my tune set at 142.5bar. My weak version A intake cam (cheap US version that was recalled for a version B cam) ruined it, but it was a fine piece and over here there are many using it without hitch. And the cost diff is definitely due to autotech being internals where LOBA and APR are being assembled and tested in shop before sending. I am unaware of availability for you all, but IE also has a very nice offering of the HPFP with options of "Kit only, rebuilding yours for you, or a new pump": http://www.performancebyie.com/ie-high-pressure-fuel-pump-hpfp-upgrade-kit-for-2-0t-fsi-engines
From the thousands of threads I've read on the differences between each of the HPFPs, the one thing that stands out for the APR & LOBA pumps is quality.
The HPFP works at by compressing fuel at high pressure (in the name), both the APR and LOBA pumps have a better sealing system which helps to prevent fuel and oil mixing.
There have been more cases of Autotech HPFPs failing and allowing fuel into the oil, then there have of APR & LOBA (although LOBA hasn't been on the market that long in fairness)
If fuel mixes with the oil it will (and has proven to) cause serious engine damage :scared:
If (read as when) I come to buy a HPFP it will be either APR or LOBA for that reason :happy2:
Nikis seen lobas fail too dude. :indifferent:
Everything can fail, just a question of which is more likely to do so.
^THIS. Nothing is completely reliable, but using a better piston design and uprated seals provide that little more security and therefore peace of mind.
IIRC Alex @ AKS has seen better performance from APR over the Autotech in the form of more consistent rail pressure
12 pages of Autotech Vs APR (thread is pre-LOBA) below
http://www.mk5golfgti.co.uk/forum/index.php/topic,25675.0.html
Autotech failure here: http://www.mk5golfgti.co.uk/forum/index.php?topic=23217.0
And poll about failure: http://www.mk5golfgti.co.uk/forum/index.php?topic=23331.0
I havent heard anything about apr or loba failing just yet but i guess id rather spend the extra money on a better hpfp that hasnt got as much of a chance failing.
But now apr or loba is the question
APR now is experiencing management/ownership changes as they went Bankrupt and have charges of design infringement in relation to grinding off competitors logos on forged bits such as superchargers and adding theirs before recasting as their own. What they will be in the near and far future is up in the air for now.
With anything, before being scared by failures, the ratio to units sold to units failed must be considered. If one in a thousand units fail, that's still reliable.
Also, in defence of Autotech, they sell just internals and rely on the skills of the person fitting and the condition of the pump being used. Assuming most people build into older pumps, that could explain the higher rates of failure.
However, I will not discredit mass opinion and facts, just like to balance arguements. :happy2: And I also don't have any of these items myself so I consider myself non-bias to any company.
Yeah I get where your coming from with that and if I got autotech I'd probes build it into my old pump so therefore will have more of a chance to fail
Don't think so.
No? Never seen or heard of one fail then?
As far as I understand, you're supposed to build the Autotech bits into a new pump?
So the cost difference between new pump + Autotech vs LOBA pump is fairly marginal.
Or you save a decent bit of money building the Autotech into your 40/60/80k miles pump, and increase your risk of it failing?
@rtechniki (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=1870) - thoughts??
Don't think so.
He told me he has mate!
The extra few quid for a Loba is a no brainer imho, it comes with a cam follower too!
