All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: Deako on January 14, 2015, 02:32:50 am
Title: Mk7 R brakes on Scirocco
Post by: Deako on January 14, 2015, 02:32:50 am
Hi all, does anyone know if the Mk7 R brake setup (calipers and specifically disc offsets) is a direct bolt on to the Scirocco? Thanks.
Title: Re: Mk7 R brakes on Scirocco
Post by: xjay1337 on January 14, 2015, 01:07:58 pm
Speak to Alex
@vRSAlex (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=1981)
He recently put a TTRS/DB9 set up on a Mk7 R .
Scirocco is same as a Golf Mk5/Mk6 brake wise so if it fits a Golf 5/6 then it would fit the Rocco.
Post by: rich83 on January 14, 2015, 01:18:20 pm
With the abundance and cheapness of the R32/S3 stuff it would be silly to overlook that first.
Anyone got information on the mk7 R piston size?
Post by: Deako on January 14, 2015, 01:25:51 pm
Basically, a full setup of R brakes would cost less than me buying TTRS/RS3 calipers, getting them refurbished with R logos, then buying TTRS discs, HEL lines, and refurbishing my rear calipers in black also.
The S3/R32 stuff will likely need refurbishing too.
If I could get a complete R setup for £700-800 would cost me less all around.
Did Alex retain the R kit as stock or did the owner keep them to put back on? :)
Post by: xjay1337 on January 14, 2015, 02:32:42 pm
Always thought the mk7 r brakes were same as anything else...345mm single.
Post by: vRSAlex on January 14, 2015, 03:21:58 pm
No reason they wont fit and work fine.
I don't have any info on the R master cylinder size, but pedal travel on the 6 pots I fitted was minimal.
The discs are 340x30mm.  Not the same as the TTS discs though.
Post by: Deako on January 14, 2015, 03:39:12 pm
They are. But seem to be a few full sets around. Just saves me hassle.
Post by: rich83 on January 14, 2015, 03:58:43 pm
http://www.ebay.co.uk/itm/Vw-Golf-R32-V6-front-brake-calipers-05-08-mk5-A3-Cupra-R-TT-K1-/301485473108?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4631ef3d54
Plus 150 for discs and pads and 20 for hoses maybe.
Post by: Deako on January 14, 2015, 05:05:15 pm
Yeah. Saw those. Too expensive for what I'd want to do with them.
Post by: xjay1337 on January 14, 2015, 05:06:00 pm
you can buy porsche 4 pots for not far off that rich.  :chicken:
Post by: rich83 on January 14, 2015, 05:10:02 pm
Fully refurbished?
Post by: Deako on January 14, 2015, 05:50:34 pm
That's the problem. Factor in refurbishing, all parts needed and getting rears to match. I could have just gone with an R setup for an OEM look.  :happy2:
Post by: Deako on January 14, 2015, 10:54:16 pm
Just thought that the rear calipers on the Mk7 R have electric handbrake mechanism. Doh!!
Post by: rich83 on January 14, 2015, 11:00:03 pm
Yeah... thats not gonna work out. Shame, theres a full set on ebay (im sure youve seen)
Post by: Deako on January 15, 2015, 12:18:07 am
Yep. There was another set that went for £750 too.
Post by: xjay1337 on January 15, 2015, 07:37:05 am
Fully refurbished?
Bit of paint and a seal kit, not that much.
Seal kit probably about £40 and powdercoating will be about 20 quid per caliper.
I just don't understand why you'd buy a set of not that good brakes for £350 + carriers + discs + pads when you can buy working, visually OK Porsche calipers which work infinitely better for £250 + carriers + discs + pads...
http://www.mk5golfgti.co.uk/forum/index.php/topic,91113.0.html
Post by: rich83 on January 15, 2015, 08:09:03 am
No one in their right mind would referb and powdercoat for those prices. Decent job you are looking at ~100 each.
Post by: Deako on January 15, 2015, 09:14:11 am
Yep. If you want a proper job done by brake caliper refurbs then you are looking at a decent chunk.
Thinking of the original plan now. Ttrs/rs3 calipers. Just undecided on custom brackets to run TTS 340m discs, or chance it on the TTRS 370m discs. Which are damn expensive.
Post by: rich83 on January 15, 2015, 09:57:28 am
I'd go down the 370mm route unless you plan to keep the car long term, thus taking advantage of cheaper 340mm consumables.
Post by: Softishman on January 15, 2015, 10:05:23 am
I am going or TTRS calipers and 370mm discs, when time come to change the discs I will look for brackets to fit a smaller disc... But until that... :driver:
Post by: xjay1337 on January 15, 2015, 10:41:53 am
Rebuild the calipers at home, off the car it's easy.
If you're paying for someone else to do it, then a good chunk of the money is time.......which is fine, but if you can do it yourself, why not?
Post by: rich83 on January 15, 2015, 11:08:48 am
Show me?? Buy some old Calipers and refurb them..... Bet you won't want to do another set.
Post by: xjay1337 on January 15, 2015, 11:13:34 am
I rebuilt calipers on my old motorcycle.. 4 pot R1 calipers.. rebuild kit cost me £18 and two evenings...
Post by: rich83 on January 15, 2015, 11:16:56 am
Good for you.....
Post by: vRSAlex on January 15, 2015, 11:21:13 am
Good for you.....
 :signLOL:
Post by: vRSAlex on January 15, 2015, 11:22:15 am
Going to say this is caps to put the point across:
DO NOT POWDERCOAT BRAKE CALIPERS.
Post by: xjay1337 on January 15, 2015, 11:41:08 am
Good for you.....
 :signLOL:
 :rolleye:
Post by: Deako on January 15, 2015, 07:13:41 pm
Now now ladies.  :grin:
Probably cheaper in the interim to go TTRS calipers, HEL lines and EBC TTRS discs. I'll be getting TTRS calipers custom painted though and rears done to match. Eventually.
Just a small matter of house sale and divorce to sort out.  :signLOL:
Post by: xjay1337 on January 15, 2015, 07:15:09 pm
Probably the best bang for your buck in that respect.
To keep initial costs down at least you could stick with the 370mm discs and get the carriers/discs for the 340mm when you inevitably warp the standards.
Post by: Deako on January 16, 2015, 12:51:22 am
Aftermarket discs prone to warp as well as the oems?
Post by: rich83 on January 16, 2015, 12:53:48 am
You'll not warp them unless you are hammering it around a track.
IIRC the 340mm fitting kit (brackets and hoses) are 250
Post by: vRSAlex on January 16, 2015, 06:53:32 pm
No one apart from Audi makes the 370mm discs.
Post by: Deako on January 24, 2015, 03:23:57 pm
Ok. So I have bit the bullet on the TTRS calipers. Just need to decide to go for OEM discs (which will warp eventually) or the VAGBremTechnic 345mm conversion kit.
£250 + discs (anything from £80 to £150) + pads
Or
£550 + pads
Post by: xjay1337 on January 25, 2015, 11:42:30 am
Go for the 340mm tts discs.
Post by: simonp on January 25, 2015, 12:50:49 pm
Bugger, that means those cheap Brembos I bought last year aren't any good as spares then?  :sad1:
Post by: Deako on January 25, 2015, 03:49:01 pm
Anyone purchased from Dave Baird (gbautomotive) on eBay before?
He is doing me a set of TTRS calipers in black with the R logo, refurbished for a really good price.
I could have got a set for £350 then paid refurb costs, but these are £400 all in. Which is a relative bargain imo. Without consumables of course though.
Post by: Deako on January 26, 2015, 10:57:06 pm
Can anyone tell me if the revised Audi TTRS discs are less likely to warp?
Post by: vRSAlex on January 26, 2015, 11:14:48 pm
They never revised them.  Still sh*te.
Post by: Deako on January 27, 2015, 09:25:36 am
Looks like I'll be getting one of Daves kits from you then.  :grin:
Post by: rich83 on January 27, 2015, 09:33:04 am
Like I said before. Depends how long your gonna keep the car.
Long term then the 340 mm kit will be best as you'll save on discs.
Short term then 370 will be fine. Chances of warping them on the road is low. Justin uses them in his 400 Odd bhp S3
Post by: vRSAlex on January 27, 2015, 07:36:56 pm
Just never brakes.
Post by: rich83 on January 27, 2015, 07:42:25 pm
 :signLOL:
Post by: Deako on January 27, 2015, 09:02:21 pm
340s are going to be cheaper even with the initial investment in the VAGBremTechnic kit.
£250 + mtec discs + suitable pads.
Post by: Deako on February 16, 2015, 07:29:20 pm
Well. Looks like I'll be raising an eBay dispute and trying for a refund as the refurb job on the calipers is distinctly average and very much DIY looking.
Powder coat too thick, causing seals to not sit flush, didn't bung the brake line input so fluid has leaked out and ruined the coating, the decals look like they have had 1 thin layer of cheap Halfords rattle can laquer sprayed over them.
I could either get a full refund or send them somewhere proper for a refurb, but the calipers already owe me £400. f*ck sake!!!
And I kerbed a wheel a couple of days ago. FML.
Post by: rich83 on February 16, 2015, 10:29:59 pm
Piss flaps!  :sad1:
Post by: Deako on February 17, 2015, 05:23:31 am
He is refunding them. Off they go tomorrow back to him. I have stuck photos on FB.
