All Things Mk5 => How to Guides / Troubleshooting => Topic started by: bigbo on November 23, 2009, 06:07:59 pm
Title: Windscrean Washers Stopped Working
Post by: bigbo on November 23, 2009, 06:07:59 pm
can anyone help with this. mine packed up about 2 weeks ago now. the wipers work but both the front and rear doesnt release any water. when i use it i cant hear any sound (motor) or anything.
Title: Re: Windscrean Washers Stopped Working
Post by: Greeners on November 23, 2009, 07:03:07 pm
First thing I'd check (after the fluid obv) would be the fuse.
After that it may be that the washer pipes are blocked or the motor itself has gone?
Good luck!  :happy2:
Post by: VC on November 23, 2009, 09:35:06 pm
Good luck!  :happy2:
indeed, no noise would indicate a fuse initially - first port of call  :happy2:
Post by: bigbo on November 25, 2009, 11:17:16 am
might be a crazy question but do you know the fuse number? i looked in the book as i thought i would do this first but it doesnt seem to have its own fuse   :confused:
Post by: bigbo on November 27, 2009, 04:57:41 pm
can anyone help with the fuse number etc????
tried the dealers today and they wouldnt help unless i booked it in
Post by: VC on November 27, 2009, 08:02:42 pm
fraid i cant help you with the fuse number, must be something out there though on tinterweb  :smiley:
Post by: snapey on November 27, 2009, 08:09:07 pm
Check the following fuses:
Passenger compartement:
F41 - 15A - rear wiper motor,
Main engine fuse box,
F19 - 30A - Wiper motor control unit.
Hope this helps, Luke.
Post by: bigbo on December 12, 2009, 04:12:18 pm
in my owners manual it says that F19 is the Radio??
Post by: njdudsbury on December 26, 2009, 08:50:10 pm
Hi all
Are you sure its not frozen with the weather we are having.
I drove up to scotland a few days ago and the temp reached -15 degrees c
wipers still worked but no water as it froze solid including the lamp washers.
There was no sound at all from the motors but after a squirt of deicer and some better temps, it started working again.
I too thought the motor was knackered, checked the fuses.
Question............. where is the fuse box in the car, as i only checked the one under the bonnet.
Post by: Nasir on December 26, 2009, 09:25:55 pm
Hi all
When mines frozen I can still hear the pump. I think there are 3 fuseboxes, 1 in the engine compartment, 1 on the drivers side and 1 on the passenger side
Post by: njdudsbury on December 27, 2009, 01:11:59 pm
Trust me when its frozen properly you cant here a thing other than the relay clicking in and out
If you can here the pump its frozen somewhere else
