All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: bad devotions on January 25, 2015, 08:37:30 am
Title: RCD 510 - SD Card Size
Post by: bad devotions on January 25, 2015, 08:37:30 am
Hi all, just wondering what size SD card can i get for an RCD 510? Is it up to 32GB? Part number for mine is 3C8 035 195 G if that helps. I have no idea what firmware i am running as i've only just got it :D
Title: Re: RCD 510 - SD Card Size
Post by: Carpy25 on January 25, 2015, 02:05:17 pm
I'm running 8 GB cards what I've found is that the fuller the card the longer start up is, a full 8 GB card takes 30-60 sec to come on after the engines started one of my other cards I have about 5 one is around a 1/4 full and starts after about 10-20 seconds even the full 8 GB card is noticeable in how long is takes to read and start 32 GB would be a lot longer I guess
Rob
Post by: bad devotions on January 25, 2015, 02:43:22 pm
Thanks for that rob. I've tried a couple of cards (16 & 2) and neither of them are being read. Is there file type restrictions or should the SD card be formatted in a particular way?
Post by: Carpy25 on January 25, 2015, 03:11:40 pm
mine are formatted Fat32 and the music is MP3 , folders for the artist and sub folders for albums if you need more than one album for that artist if not just copy and paste albums in to the SD card directory , not put single sings in but if I did I would use a various or favourites folder as they list A-Z single songs would be all over the place
Rob
Post by: bad devotions on January 25, 2015, 04:13:45 pm
Sussed it. My 2gb card is working ok. It seems the SD card slot is a little stiff that's all.
Post by: Carpy25 on January 25, 2015, 04:17:34 pm
happy days :happy2: load up the spice girls and go for a drive  :driver:
Rob
Post by: bad devotions on January 25, 2015, 04:25:37 pm
Lol! Woop woop!
