All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Tfsi_Mike on January 30, 2015, 11:12:00 pm
I have an issue where my drivers door fails to lock when reaching the preset speed.
If I press the unlock button in the centre console & then reach that speed again (15mph?) the door then locks.
It makes a noise the 1st time but if I lower my window and try and open the door from the outside it still opens
I haven't got Vcds handy atm. Is it a common issue/ fault?
Thanks for any advice.
Mike
I had the same issue in my eddy was driver door controller. :happy2:
Thansk @Orc (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=9637). Are there many variants? So I can start shopping around. @Eddie-NL (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=2345) @mortygttdi (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=203)
Thanks again.
I assume it's eBay item; 231461232645
Make sure you buy correct side as both sides have different part number.
About year ago i replaced N/S and now looks like other side is failing ...
Was it just a case of noting the coding in the existing one and copying it into the replacement one?
Saw they are sided, cheers
