All Things Mk5 => Mk5 General Area => Topic started by: EddieA on February 06, 2015, 07:52:35 pm
Title: Sat nav and Highline
Post by: EddieA on February 06, 2015, 07:52:35 pm
probably going to be a really simple answer to this.
when i bought the golf it never came with sat nav or the highline display and no multifunction steering wheel.
i have since added all the above (rns 510, highline and multi function) my question is i can't control the music from the buttons other than the volume, it also doesn't display the song or even the satnav details on the highline.
is there a way that i can get this?
Title: Re: Sat nav and Highline
Post by: skard on February 06, 2015, 07:55:15 pm
When it was coded in, was 37-Navigation selected in module 19-Gateway?
Post by: EddieA on February 06, 2015, 08:03:52 pm
in all honesty i couldn't tell you. and i don't have vagcom to check.
Post by: JoeDarKa on February 06, 2015, 08:29:35 pm
Sounds like a coding issue
Post by: skard on February 06, 2015, 08:32:04 pm
Where are you situated so a VCDS owner can maybe help you?
Pretty sure what I wrote will get you on your way
Post by: EddieA on February 06, 2015, 08:41:56 pm
thanks for that - will have a look if i can find someone local to have a check for me
Post by: Cr33D on February 07, 2015, 11:47:58 am
Hey Eddie I'm in Portsmouth with full vcds, if it is any help to you...
