All Things Mk5 => Mk5 General Area => Topic started by: Shahid8850 on February 12, 2015, 07:36:41 pm
Title: Coming home lights enabled but not working
Post by: Shahid8850 on February 12, 2015, 07:36:41 pm
Hello,
I have read many listings but nothing is like the problem I have.
The coming and leaving home lights are enabled as I have check using VCDS however when ever I lock or open the car the lights never come on. I have the light and rain sensor so the lights come on automatically when dark.
Has anyone had this issue or know how I could fix this.
Title: Re: Coming home lights enabled but not working
Post by: jaffa on February 12, 2015, 08:24:20 pm
Mine stopped working for a while
I had it activated on vcds and still didn't work.
I then deactivated it and saved it then activated it and saved it and it's worked ever since
Still don't know why it stopped working
Post by: J400uk on February 13, 2015, 07:17:15 pm
Have you checked they are set to the correct length? I've been caught out in the past when I've enabled them but forgotten to key in a length. The problem is the length will default to 0 seconds which means they never come up, so you need to put it up to 30 seconds or whatever.
Post by: Shahid8850 on February 14, 2015, 02:51:56 am
Yeah I checked the length and it was set to 30, so not sure what the issue is
