All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: anderson9 on February 14, 2015, 06:54:51 pm
Title: How to fit hid kit?
Post by: anderson9 on February 14, 2015, 06:54:51 pm
Has anybody fitted these I can't find out how to connect the bulb to the car ?
Title: Re: How to fit hid kit?
Post by: screech on February 14, 2015, 09:05:25 pm
Find nearest bin, open, insert... Job done.
Sorry.
Post by: Andy on February 14, 2015, 09:10:45 pm
hids in normal lights are horrendous and don't don't give proper beam pattern so blind on coming traffic
Post by: StuF on February 14, 2015, 09:11:31 pm
Sorry.
x2
Dangerous, illegal and bad for other road users through being dazzled by the chavvy "its blue innit" bulbs
Post by: jaffa on February 14, 2015, 09:55:01 pm
X2 don't use them unless you have projectors
I'm sick of being blinded by corsas with hid's fitted
Post by: Kam88 on February 14, 2015, 10:17:11 pm
By the looks of it great help from everyone above. Hard to explain fitting over forum have a look at YouTube they are dead simple take about 10 mins
Post by: boardyuk on February 14, 2015, 10:29:07 pm
Please don't fit these unless you have projector lights, you'll blind everyone else on the road. I've installed a 5000k HID xenon conversion kit in some Depo projectors recently and it's really simple to do, just follow the instructions provided.
Post by: anderson9 on February 15, 2015, 12:14:37 pm
Calm down lads here not going in standard headlights, does the positive and negative need wiring to the battery ?
Post by: boardyuk on February 15, 2015, 12:21:02 pm
The HID kit should come with ballasts which connect to the original wiring and then the bulbs connect to the ballasts. If you have a look at my build thread you can see my Depo lights setup ready for the going in the car.
Post by: anderson9 on February 15, 2015, 12:45:40 pm
So they don't need wiring to the battery ?
Post by: Kam88 on February 15, 2015, 08:03:23 pm
Only h4 bulbs need battery feed otherwise no you connect everything to ballast and from balast to headlight
Post by: anderson9 on February 16, 2015, 08:42:18 pm
I've had to order some bulb adapters for them, as I don't get a connection to the headlight
Post by: Kam88 on February 17, 2015, 06:03:34 pm
What bulb is it h7 or h1 ? Where are you based ?
Post by: anderson9 on February 22, 2015, 09:07:54 pm
H7 bulb, I'm in Newcastle, I've fitted them now.
