All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: TForrest94 on March 10, 2015, 03:50:19 pm
Title: mk5 r32 rear brake upgrade... the great debate about dust shields
Post by: TForrest94 on March 10, 2015, 03:50:19 pm
Afternoon all, ive managed to get my r32 front brakes fitted and bedded in they need a good bleeding but i dont wanna do this till the rears are on
Now the garage thats been doing the work wernt happy to fit the rears in the same sitting due to the dust shields being too smalL
i know a lot of you guys just bend or remove them but all parties on this side would feel a lot better would feel something in placw for peace of mind
now heres my plan: i know fabricating completly new shields would be an incredible waste of resources but if i was able to get a set of r32 shields and gti shields would it be possible to join them together with the power of welding?? Or do the fitting vary substantially that it wouldnt be possible?
Any input is always appreciated
Tommy
Title: Re: mk5 r32 rear brake upgrade... the great debate about dust shields
Post by: Andy on March 10, 2015, 04:52:12 pm
Why not buy and fit the shields like i did
Post by: rich83 on March 10, 2015, 04:58:04 pm
Push them back... They will work fine.
Post by: TForrest94 on March 10, 2015, 05:06:45 pm
From what ive read are the hub fitments not different?
i told the guys to do thag at the start and he wasnt happy about it, proper by the book which has its advantages i suppose just weighing up the options really
Post by: Andy on March 10, 2015, 05:15:28 pm
On my gttdi only one screw didnt line up but it's held solid with the rest
Post by: Beddie on March 10, 2015, 06:57:50 pm
I believe Eos V6 rear shields 'may' fit as that had the larger rear brakes but was a fwd platform  :smiley:
Post by: TForrest94 on March 11, 2015, 05:59:14 pm
think this may be the way forward then cheers for the advice
I had a quick look and it diesnt look like they are gonna be big enough, love the thinking though cheers
Post by: omeydz on March 11, 2015, 07:54:11 pm
The shields screwed in perfectly on my MK6 and its FWD
Make sure you get the shields right way round!
Title: r32 rear shields fit (see bottom)
Post by: TForrest94 on March 14, 2015, 11:06:48 pm
Just to bring a happy ending to the thread, got the rear brakes on today and fitted with matching rear shields, in regards to fitment 2 of the 3 stqndard holes fit, and then another was simply drilled to make 3 connections to the hub
Thought id just through this on here for future reference as i only read posts saying major fabrication would have to be done, it doesnt appear to be the case!
Happy modding guys  :happy2:
Post by: Andy on March 15, 2015, 12:18:01 am
glad you got it sorted
Title: Re: r32 rear shields fit (see bottom)
Post by: Dave J on March 15, 2015, 08:38:15 pm
Nice work! Sounds a good outcome - could you let us know the part numbers that you used?
I take it you used the EOS V6 rear shields in the end?
Post by: TForrest94 on March 16, 2015, 10:30:42 am
Ill check the tps invoice later snd post them on here
na went with r32 ones used a mates 2007 reg dunno if that affects anything
Post by: TForrest94 on March 18, 2015, 02:11:06 pm
1k0615611s
1k0615612s
Post by: 993BOY on September 07, 2016, 10:29:56 am
1k0615611s
1k0615612s
I have the R32 dust shields with serial numbers as above and found that they don't fit very well. Like you say, only 2 holes align.
Did you have to remove the hub to get the shields on, because I have failed to get the dust shield over the hub (the thing with the wheel bolt holes in)!!??
Cheers,
Nick
