All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: stevie040 on March 13, 2015, 10:42:58 pm
Title: Judder and flashing engine light!!!
Post by: stevie040 on March 13, 2015, 10:42:58 pm
After a bit of help. The cars been running fine since I bought it 2 months ago. Had it mapped straight away and been loving it.
However just a minute ago I put my foot down in fourth and felt like a judder and struggling to boost. The engine management also flashes at the same time. Haven't got vag com unfortunately but anyone got any ideas??
Title: Re: Judder and flashing engine light!!!
Post by: Leonpettit on March 14, 2015, 07:46:49 am
Coilpacks by the sounds of it pal
Post by: bigeyd on March 14, 2015, 07:59:16 am
You need vagcom where are you,plenty of helpful members all over the UK on here.
Sounds like the common coil pack
Post by: stevie040 on March 14, 2015, 06:36:41 pm
Read the codes and has cylinder 2 misfire. My concern is I seem to be burning a lot of oil to. There is evidence of a leak around the cam cover sill, and the oil filler cap although the pcv system appears to be working.
I've been reading about low compression can cause misfires and another sign of low compression is burning a lot of oil
