All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: KieranR on March 16, 2015, 07:53:15 pm
Hi. Hoping someone here can help. My bluetooth module has stopped working. I was on a phone call and it just died. Managed to reconnect my phone to it but then the same thing happened again and now it doesn't even show up in the list of bluetooth devices when I search for it.
I scanned the car and the results are below. Is there any fix for this or is the module gone bad?
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 77
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0GN3NF881
Coding: 040300031C070060
Shop #: WSC 01279 785 00200
VCID: 3467FA5B57CEB4BE40B-8061
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 044 J HW: 02E 927 770 AE
Component: GSG DSG 081 1407
Revision: 04608010 Serial number: 00000709201237
Coding: 0000020
VCID: 1C3732FBDF5E1CFE68B-8049
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
VCID: 73E539471240F386991-8026
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HB HW: 1K0 820 047 HB
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6BD521274A702B46511-803E
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007786123
Coding: E58D0F2700041500471400001400000080097F075C000108000000000000
Shop #: WSC 01287 785 00200
VCID: 71E9334F685CC1966BD-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 151107 021 0501
Coding: 00038805
Shop #: WSC 01287
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 211107 046 0204
Coding: 00208933
Shop #: WSC 01287
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1LGWZP
Coding: 0013112
Shop #: WSC 01269 785 00200
VCID: 3D71DF7F648475F6BF5-8068
Subsystem 1 - Serial number: 6332MSME28021246$
Subsystem 2 - Serial number: 6342MSME28022C536
Subsystem 3 - Serial number: 6352QSME48523D61J
Subsystem 4 - Serial number: 6362QSME490C472FV
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0100
Coding: 0012112
VCID: 78FF0E6B0B2690DEAC3-802D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 864 HW: 1K6 920 864
Component: KOMBIINSTRUMENT VDD 1214
Revision: V0002000 Serial number: VWX7Z0GN3NF881
Coding: 0003103
Shop #: WSC 11959 000 1048576
VCID: EFEDB537FE685766FD9-80BA
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 051107F2000617
Coding: ED801F060006020001
VCID: 306FF64BA3D6889E243-8065
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 211
Mileage: 106415 km
Time Indication: 0
Date: 2000.00.00
Time: 18:31:17
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1214
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1208
Coding: 0000564
VCID: 387FCE6B4BA650DE6C3-806D
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3663C05341B2A6AE7EF-8063
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 18C802087F2D840DC85A069010CC
Subsystem 1 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000564
VCID: 3979CB6F70AC49D693D-806C
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3P0382810
Coding: 01000401040005
Shop #: WSC 00020 790 12345
VCID: 24470A1B272E243ED0B-8071
1 Fault Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 211
Mileage: 106422 km
Time Indication: 0
Date: 2000.00.00
Time: 19:56:22
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666741892
Coding: 0A10010000010110
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3C77D27BB79E7CFE88B-8069
End ---------------------------------------------------------------------
Quick bump. Can anyone she'd any light on this?
You say the module cannot be found when you search for it with your phone, but is it still recognized by the head unit? Have you tried resetting it to factory defaults?
When I go to the phone menu it Says something like "Mobile Telephone Not Inserted or Connected". Also when I go to the Media section the BT Audio feature is greyed out.
I tried disconnecting the battery but It didn't do anything. When I first got the problem I did the factory reset. Will try again.
If I don't plug in the module at all I cannot access the phone screen or the media section so it does seem to be doing something. Definitely seems like there is a fault with it though and I only got it at Christmas.
Do these modules fail often I wonder? Reluctant to buy another one if this is going to happen again
Sounds like your head unit is aware of the bluetooth module then. Do you have a 'Telephone' menu on the MFD? I have a 3C8 module (9wZ, similar to 9w7 as you have) and I initialize the pairing from the MFD, not from the phone. Are you able to do so? I also have a 'Visibility' option, do you have that so you can check that it is enabled? Don't know why it would have been disabled in the first place, but anyway...
My last suggestion is to physically inspect the wiring harness at both ends to look for damaged or bent pins, do a continuity check etc.
check all wiring and unplug and plug back in the bluetooth unit cables
Dont have the Telephone menu in the MFD as I don't have the highline clocks. I think the next option is to inspect the wiring and maybe try pairing with a different phone. I'll update if I have any success
