All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: mk4gti-t on March 20, 2015, 05:17:31 am
Title: RNS510, mfsw and highline coding issues.......
Post by: mk4gti-t on March 20, 2015, 05:17:31 am
I've recently fitted an RNS510 but can't get the track up and down buttons working correctly  :confused:
When I change the code in the navigation module to get them to work it stops the mfd displaying the compass direction in the top left hand corner of the screen.
Also I can't scroll through audio, set up, navigation menus etc even with the stalk buttons?
Any ideas as to what the coding should be?
My car is a 2005 gti dsg and I've fitted highline dash, old style mfsw with paddles and RNS510. I've also swapped the steering wheel controler to the 'ch' type.
Strangely though when I had a newer type mfsw without paddles all worked fine???
Title: Re: RNS510, mfsw and highline coding issues.......
Post by: skard on March 20, 2015, 07:30:55 am
Unticked BAP in the coding for stereo?
Post by: mk4gti-t on March 20, 2015, 07:38:14 am
Yea the compass comes back but the track up/down buttons stop working then.....
Post by: skard on March 20, 2015, 07:43:11 am
Did you have a GPS compass module before the RNS510?
Post by: mk4gti-t on March 20, 2015, 11:42:22 am
I used to have an mfd2 and got the gps antenna off eBay. It all worked fine then.
Post by: skard on March 20, 2015, 02:45:42 pm
The GPS compass module is seperate to the stereo. Probably rare for a mk5 to have it but if you do, it can interfere with the RNS510 until you deactivate/unplug it.
Post up a scan.
You probably have a later cluster that is intended for use with the newer MFSW buttons.
Post by: mk4gti-t on March 20, 2015, 03:08:57 pm
No can't find a compass module installed anywhere. My cluster part number is 1K6 920 972 D not sure how old or new that is though?
Post by: skard on March 20, 2015, 03:45:05 pm
That cluster is the new button generation but should work ok.
Have you got a scan to post up?
Post by: mk4gti-t on March 20, 2015, 03:57:48 pm
No sorry need to get it to my mates to get a scan. What should I be looking for to post on here? Thanks for the help by the way  :happy2:
Post by: olsen-72 on March 20, 2015, 08:05:35 pm
My buttons didnt work properly until i changed wiper stalk for the one without buttons.
Post by: mk4gti-t on March 20, 2015, 08:08:08 pm
How did you get to the menus on the display then? I have no menu button on the old style steering wheel.....
Post by: olsen-72 on March 22, 2015, 09:34:22 pm
Well.. I have mk6 steering wheel mate
Post by: mk4gti-t on March 22, 2015, 10:28:44 pm
Oh I see......
