All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Rukz on March 21, 2015, 08:32:09 pm
Title: RNS 510 light sensor
Post by: Rukz on March 21, 2015, 08:32:09 pm
Good evening all,
Is there anyway to deactivate the light sensor (located on the top right corner) on the RNS 510?
I want the manual brightness settings chosen in the set up menu to take full and final priority without the light sensor overriding and dimming the screen.
Thanks in advance  :smiley:
Title: Re: RNS 510 light sensor
Post by: Rukz on March 23, 2015, 08:29:30 pm
Anyone ??  :smiley:
Post by: Rukz on March 26, 2015, 07:04:05 pm
Guess not  :confused:
Post by: Golf_GT_TDI on March 26, 2015, 07:27:27 pm
If you fancy taking it apart you could do it, I have no idea if it could be done via custom firmware
Post by: Rukz on March 26, 2015, 07:45:24 pm
Opening it up.... Well ideally no I wouldn't want to do that. Nonetheless, how would I do it if that's the only route to go down? Cheers
Post by: Golf_GT_TDI on March 28, 2015, 03:38:35 am
I guess it's just using a LDR so desoldering and placing a 5k resistor there should do it?
Post by: Rukz on March 28, 2015, 04:53:41 pm
Sounds like a good idea... However, it also sounds just a bit too scary for me  :scared: definitely not something I'll be able to do :driver:
