All Things Mk5 => Mk5 General Area => Topic started by: Pesky jones on April 03, 2015, 12:54:24 pm
Title: ticking
Post by: Pesky jones on April 03, 2015, 12:54:24 pm
Can anyone tell me this tick? I don't know whether it's always done it or whether it's started recently to be honest! Ive read it could be the injectors or it could be something worse. Does yours sound like this... 05 dsg gti
https://youtu.be/OHLeL1oS3xQ (https://youtu.be/OHLeL1oS3xQ)
https://youtu.be/gqVvVkDnJU0 (https://youtu.be/gqVvVkDnJU0)
Title: Re: ticking
Post by: Matthewsimone on April 03, 2015, 01:38:09 pm
Videos wont play for me mate!
Title: Re: ticking
Post by: OSB on April 03, 2015, 01:42:03 pm
Won't play for me either!
Title: Re: ticking
Post by: Pesky jones on April 03, 2015, 03:04:44 pm
Should work now, they were set to private - doh!
Title: Re: ticking
Post by: StuF on April 03, 2015, 03:08:47 pm
Sounds like the injectors to me! Normal noise from the TFSI engine
Title: Re: ticking
Post by: OSB on April 03, 2015, 04:55:55 pm
Yep. I'd agree. Injectors and HPFP. Lovely quiet engines these!
Title: Re: ticking
Post by: Pesky jones on April 03, 2015, 05:17:18 pm
Cool  :smiley: it's not very loud in the car, just noticed it when I got out the car with the engine on and the bonnet up. Cheers guys
Title: Re: ticking
Post by: muff1991 on April 03, 2015, 05:54:24 pm
My 06 sounds like this too but it's quite loud inside the car, really does sound like a diesel lol
Title: Re: ticking
Post by: Pesky jones on April 04, 2015, 07:33:30 pm
Weird how it's louder in one video then the other as well!
Title: Re: ticking
Post by: Pesky jones on April 08, 2015, 09:41:30 pm
Pretty sure it's the injectors just to clarify,  realised today if you gently feather the accelerator, you can hear the ticking build up into a continuous hum.
Title: Re: ticking
Post by: Pesky jones on April 20, 2015, 08:45:41 am
Does this make sense? Or if it was a bad cam belt was the cause would the ticking also increase?
Title: Re: ticking
Post by: dazza on April 20, 2015, 10:11:59 am
Here is how mine sounded before and after i changed the cam chain, tensioner and adjuster.
The after is much quieter due to mic positioning but it sounds a little less like a diesel now.
before:
http://daz.co/audio/open.mp3
after:
http://daz.co/audio/carnew1.mp3
after with revs:
http://daz.co/audio/after_1.mp3
Title: Re: ticking
Post by: GTIEagles on April 20, 2015, 11:11:57 am
@dazza (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=10457) Has anyone actually had a cam chain snap or does it get changed to mainly prevent the noise?
Title: Re: ticking
Post by: rich83 on April 20, 2015, 11:21:34 am
Im mainly the plastic tensioner that wears down and can snap/break. But as you are doing that you so the chain too.
Title: Re: ticking
Post by: Pesky jones on April 20, 2015, 11:36:55 am
My belt/chain(which is it?) should be ok, it got changed 20k miles ago with the water pump, Would the tensioner get changed at the same time?
Just wanna ask again, would the ticks increase in frequency with gentle acceleration if it was a bad cam belt anyway?
Dazza, in your audio I can only hear one ticking, in the “fixed” audio it is slightly quieter. Should I be hearing two types of ticking – one being injectors and one being the bad cambelt?
Title: Re: ticking
Post by: rich83 on April 20, 2015, 11:47:12 am
^^ just to clarify.
Timing belt and tensioner is one thing.
Cam chain and tensioner is something else.
Title: Re: ticking
Post by: Pesky jones on April 20, 2015, 11:50:03 am
^^ just to clarify.
Cheers. In my service history -it just says toothed belt with a tick in the box - is this a timing belt or a chain?
Title: Re: ticking
Post by: rich83 on April 20, 2015, 11:51:11 am
Timing belt. (on the left side of your engine as you look at it)
Timing chain is on the right behind the fuel pump.
Title: Re: ticking
Post by: dazza on April 20, 2015, 11:52:01 am
The ticking is normal. Its the chainy diesel sound you have to worry about. Its hard to tell from these audio clips but i do think it sounds better.
@Peskyjones (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=11854) you have a belt and chain.
@cnut (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=11011) As rich said Some engines have failed due to the chain/tensioner. Usually the AXX engines i believe.
Title: Re: ticking
Post by: dazza on April 20, 2015, 12:34:28 pm
Tried to get a better audio of how it sounds now. Nice and quiet  :signLOL:
http://daz.co/video/20150420_130604_1.mp4
Title: Re: ticking
Post by: Pesky jones on April 20, 2015, 01:39:39 pm
Cheers guys. So is the timing belt also known as a cam belt?
Why do I have a timing chain as well as a timing belt? Do they do different things? Does the timing chain need changing after X miles like the timing belt does? Such a noob.
Title: Re: ticking
Post by: dazza on April 20, 2015, 02:09:52 pm
I don't think the cam chain is a serviceable item to be changed in x miles.
Worst case scenario.
http://www.mk5golfgti.co.uk/forum/index.php?topic=93695.0
Title: Re: ticking
Post by: rich83 on April 20, 2015, 02:49:08 pm
You dont... you have ...
a timing belt.... Which links the crank shaft to the exhaust cam
a CAM chain... which links the exhaust cam to the inlet cam.
Title: Re: ticking
Post by: Pesky jones on April 20, 2015, 03:50:02 pm
that looks like a pretty bad scenario to be in! Probably safe to say that mine hasn't had them changed then unless its in an invoice, which it isn't. Think I'm going to have to get them done at some point, but I've already got a long list of things that need doing first
Guess i'll have to fit it in somewhere, but seeing as it its not making the diesel noise (judge for yourself on first page) It can wait a while. Maybe on the list for later this year/early next year.
Title: Re: ticking
Post by: Pesky jones on April 20, 2015, 07:29:17 pm
@dazza (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=10457) what do you think
https://youtu.be/YX5C050w6qc (https://youtu.be/YX5C050w6qc)
Title: Re: ticking
Post by: dazza on April 20, 2015, 08:20:33 pm
The cam chain/tensioner is not cheap to get done especially if you end up getting the adjustor changed as well.
I don't really want to advise you to spend money if you don't have to.
Here is a good one to have a listen to. Ignore the tapping this is normal. It sounds less like a diesel in the second clip.
http://www.mk5golfgti.co.uk/forum/index.php/topic,87599.msg913347.html#msg913347
Title: Re: ticking
Post by: Pesky jones on April 21, 2015, 12:26:01 am
I'd say mine doesn't really sound like either of those, but don't think it is as bad as the first clip. Hopefully it's fine - just high mileage without replacement is worrying me
Title: Re: ticking
Post by: Pesky jones on April 23, 2015, 08:54:24 am
Is the ticking a high pitched ticking? I'd say I can hear a seperate ticking quote prominently which is sperate to the injector tick
Title: Re: ticking
Post by: GTi-Andy on April 23, 2015, 09:07:59 am
@dazza (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=10457) your becoming a real guru on this subject now fella!
All I'll say on this subject is, I had dieseling sound from engine, so much so I could hear it inside the car with the doors shut.
So changed the cam tensioner, chain and cam adjuster. Now all is lovely and quiet, no embarrassing diesel noise for me.
I would say, if you can hear the diesel sound from inside your car, get the parts changed. If you cant leave alone.
Dazza helped me a lot with advice on mine, listen to what he has to say
Title: Re: ticking
Post by: dazza on April 23, 2015, 09:53:17 am
@GTi-Andy (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=10725) Thank mate happy to help out fellow members.  :happy2:
@Peskyjones (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=11854) I was exactly the same as you at first concerned about the ticking noise. Even after changing the cam chain, tensioner and adjustor it still ticks. You need to forget about this its normal. Most of the ticking i have is from the HPFP so i'm keeping an eye on the cam follower.
As Andy said its the diesel sound that you have to worry about. Can you hear this in the cabin?
Title: Re: ticking
Post by: Pesky jones on April 23, 2015, 10:32:37 am
Well I'm still not entirely sure what the diesel noise is and what the injector noise is!. From inside the cab at idle I can hear a lower pitch ticking, but this is the noise that increases in frequency when I feather the accelerator - which makes me think it's the injectors?
When I open the bonnet I hear the higher pitch ticking
