		All Things Mk5 => Mk5 General Area => Topic started by: vag12 on April 15, 2015, 01:00:16 pm
				Just need some information regarding engine swaps, my mates golf R with CDL engine has starved of oil and been looking for a replacement, Only one he has found is a BHZ engine. He is running 370bhp and 380lbs of torque before the engine failed, so needs info regarding the BHZ block will be fine for a straight replacement without the need to adjust the map or anything?
				Engine will bolt in fine, inlet camshaft is different so map will require tweaking
				so definately will need tweaking? I thought the BHZ and CDL is almost identical
				CDL has a better inlet cam lobe for the HPFP providing more fuel pressure  - who mapped it? All tuners will have an equivalent map for the BHZ.
Was mapped by r tech but they don't have a slot for weeks now so just really wanted to know will it be safe as it is since the bhz can handle the same amount of power usually
				Think you better speak to Niki  :happy2:
