All Things Mk5 => Mk5 General Area => Topic started by: Bish155 on April 19, 2015, 04:40:12 pm
I'm looking to change my rear discs and pads on my edition 30, but there seems to be a few sizes available, does anyone know what size is correct?
286mm :happy2:
Top man, don't suppose you know the part no?
They also come in 282mm which is also a solid disc and eradicates the scabby lip that forms on 286mm discs
With all your mods, isn't it a good time to upgrade to R32/S3 rears :evilgrin: ?!
Don't know the cost of this, will have to look into it. :happy2:
Hi all!
The part no of the discs is 1K0615601AD. ;)
Also if you whould like a cheap R32 setup look for these part numbers:
TRW BDA690 - R32 caliper carrier rear left
TRW BDA691 - R32 caliper carrier rear right
TRW BHS938 - R32 caliper rear left
TRW BHS939 - R32 caliper rear right
I started looking for TRW part numbers after i've seen that my Cupra OEM rear brakes were made by them, so they are the same thing but a lot cheaper.
Zimmerman 100.3309.20 - rotors 310x32mm (not OEM, a cheap quality product as long as u stay away from drilled ones)
You can always go for Caddy calipers, which have the same 41mm pot as the R32 caliper using stock caliper carriers and discs, but the bigger vented R32 rotors will give more cooling.
