All Things Mk5 => How to Guides / Troubleshooting => Topic started by: StuF on May 01, 2015, 09:07:26 am
Title: High Pitched Squeeling When Coming Off Boost
Post by: StuF on May 01, 2015, 09:07:26 am
Good morning,
Today I was driving to work with the window open and noticed a strange noise when coming off boost
Basically when backing off the acclerator I hear a high pitched squeeling noise that sounds like a dry bearing - however the noise only happens when I back off pretty suddenly. Only lasts a second or so like pressure is being released.
Am I correct to assume it is a blocked or semi blocked PCV - car is an 08 GTI, unmapped and isnt loosing any boost when under load.
For interest sakes how much is a replacement PCV?
Many thanks for your help in advance  :happy2:
Title: Re: High Pitched Squeeling When Coming Off Boost
Post by: StuF on May 01, 2015, 09:18:08 am
I have removed the dipstick with the engine running and the idle doesnt really change although the valve does make quite a noisy hiss
Will have to pop into VW today and grab one and see if that rectifies it!
Post by: StuF on May 01, 2015, 02:58:58 pm
Fixed - new PCV from GSF for £25! Winner :happy2:
No more nasty noises
