All Things Mk5 => Mk5 General Area => Topic started by: Georrge on May 05, 2015, 06:45:32 pm
Evening,
As of yesterday, the driver's side door has started to decide it doesn't want to unlock sometimes; resulting in me having to use the key. It sounds as if it unlocks, but nope. It's a temperamental fault, doesn't do it every time but it is becoming annoying.
Any one else had this, or any idea what can be done to fix it?
Cheers!
Most likely this issue
http://www.mk5golfgti.co.uk/forum/index.php/topic,52585.0.html
But get it scanned to confirm the fault! :happy2:
Thanks for that guide! That looks like a load of fun.. :signLOL:
It's not as bad as it looks but you can get issues with the door wiring - this is worth a read just in case.
http://www.myturbodiesel.com/wiki/door-wiring-harness-cracked-wire-replacement-mk5-vw/
