All Things Mk5 => Mk5 General Area => Topic started by: JimmyC92 on May 14, 2015, 06:34:39 pm
The lumbar support in my driver seat appears to have broken, when I press the button to adjust it, a clicking noise starts, it sounds like it's come off the runners or something. Is there anyway to check?
Go in from the back of the seat.
Unhook the the bottom plastic strip that is stitched into the fabric/leather from the frame. You will feel where it goes in.
Then unhook the plastic strips that run up either side of the storage compartment in the back of the seat.
This will give you enough room to see the lumbar support. It is only plastic.
I belive that the motor can be accessed from under the seat (seat removed).
