All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: ruhaleali on May 19, 2015, 01:38:05 pm
Title: Difference between rns510 version C vs Version D
Post by: ruhaleali on May 19, 2015, 01:38:05 pm
Whats the difference guys ?
Title: Re: Difference between rns510 version C vs Version D
Post by: RetroRaz on May 19, 2015, 02:25:54 pm
Some version C are lcd and some are Led.  All version  d are led. But be careful as some lcd ones when upgraded,  the part number in the secret menu changes to version d.
If you have a star button top right corner then its led.
I have had led and lcd but see little  difference in quality of image.
Post by: Shoduchi on May 19, 2015, 05:48:28 pm
I have a RNS-510 version A and version P. You can tell the image isn't the same but not much difference. The LED version has a bit more contrast.
Both have the same functionalities since the version A has the FW 5238 and the version P has the FW 5274.
Post by: RetroRaz on May 19, 2015, 07:02:14 pm
Only time i saw a major difference is when i upgraded from firmware 1300 to 3810 and then the bootup was quicker.
Post by: Shoduchi on May 19, 2015, 08:08:57 pm
At the moment I don't see much difference in boot up times. I never timed, though. :laugh:
