All Things Mk5 => Mk5 General Area => Topic started by: K9 on May 25, 2015, 10:04:56 pm
Title: Going for stage1 custom map. what to do before map?
Post by: K9 on May 25, 2015, 10:04:56 pm
hey. i'm booked in for a stg1 custom map on Rototesters. The car is a gti AXX with 53k miles on it and a fresh cambelt with waterpump from vw. 200miles ago. Ordered a Rev.G DV from a member of here and checked the dipstick test and oil cap test and the car went nuts when i opened the oil cap  :rolleye: anything else that i need to chec/do before rototest and map? will be dricing with shell V-power. Should i put a full tank v-power and injection cleaner?
Title: Re: Going for stage1 custom map. what to do before map?
Post by: PT82 on May 25, 2015, 10:23:32 pm
Cam follower and budget for a new clutch in future if manual.
Post by: dansmith180 on May 25, 2015, 10:52:43 pm
As above do a can follower, would also be good to do precat removal and panel filter to gain a few extra cheap horse powers.
If you use injection cleaner then it's a good idea to do an oil change not too long afterwards as well.
Post by: Scottymon on May 25, 2015, 10:54:55 pm
Defo do a Cam follower inspection if you haven't already...
PCV "seems" ok
Your clutch may slip, as said above, if so ask them to dial it back a tad, torque is fun but it destroys clutches and tyres (if not linear).
Don't do the injection cleaner this time imo, unless as above your dropping the oil... but do a few half tanks of vPower if you don't usually use it; and have enough fuel for the mapping.
Most of all, have fun on your return journey/s ;)
Post by: rich83 on May 25, 2015, 10:59:56 pm
Injector cleaner doesn't require and oil drop afterwards... At least the bg44k doesnt
Post by: dansmith180 on May 25, 2015, 11:13:46 pm
After doing some reading I changed mine after BG44K, to be fair it had been 5K so I was planning on it anyway.
Post by: rashg60 on May 25, 2015, 11:14:07 pm
I'm also booked in for a stage 1 remap in the next couple of weeks - no one told me about a clutch???
Would this need to be replaced soon after the remap? Are any other parts affected by the remap and need changing?
I've got a completely standard 2006 manual gti at present and was only thinking about doing the stage 1 remap to give it some extra power. I'm slightly hesitant now.....help!
Post by: Scottymon on May 25, 2015, 11:17:10 pm
Depends on the torque... don't go crazy with it and you'll be fine. :happy2: under 300lb-ft with a nice curve "should" be ok, but it really depends on how much life is left in your 10 year old clutch!?
Post by: rashg60 on May 25, 2015, 11:32:18 pm
If it does need replacing, what would be recommended?
What do people normally go for and what works well with the Stage 1 remap?
Post by: dansmith180 on May 25, 2015, 11:36:11 pm
Helix organic clutch with new OEM DMF. As above with a good linear map it should be fine on stage 1 but you never know, some go with 40k miles stage 1 and some are fine with 100k stage 2+, it's a risk but at stage 1 it's a small one.
Post by: K9 on May 26, 2015, 06:49:18 am
How about when i have a dsg gearbox? Got LC as standard. And i made a oil change let's say about 1000km 5w40 and i never filled my tank with 95. 98. Always shell v-power. So i injection cleaner wont help anything. And the cam follower, is it okay if i change it after mapping? @Scottymon (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=7640)
Writen with my fingers
Post by: Scottymon on May 26, 2015, 08:47:50 pm
^ Sure, however your tuner will probably do it for you if you ask. :thumbs
Post by: K9 on May 26, 2015, 11:25:42 pm
Whats the max. Torque i can take out from the factory dsg software? He told me i would get like 425nm and 250-260hp
Post by: GrayMK5GTI on May 27, 2015, 11:42:58 am
Replace the fuel filter as well. Its under the rear sill on driver side. not noramally a servicable item but they do get clogged up. go for the 6.6bar version  :happy2:
Post by: Shoduchi on May 27, 2015, 12:22:01 pm
What's the part number of the 6.6 bar fuel filter?
Post by: TaylorGTi on May 27, 2015, 12:26:42 pm
Also after a fuel filter but what's different with the 6.6bar one and oem unit!
Post by: Shoduchi on May 27, 2015, 05:28:04 pm
I rechecked the part number and I ordered the correct one. It's 1K0201051K, for anyone who's interested as well.
Post by: flashp on May 27, 2015, 05:55:08 pm
I'd be more keen to have a custom map applied by somebody that could tell me what else they'll be checking or that would need changing before they went ahead.
Post by: K9 on May 27, 2015, 06:34:09 pm
Will be doing the cam follower and fuel filter after map. Is there any idea to go dsg stg1 juat becouse i'm mapping stg1? Will the torque be good for the box?
Post by: K9 on May 28, 2015, 10:03:28 am
Any1 know?
Post by: GrayMK5GTI on May 28, 2015, 10:07:33 am
DSG mapping gives you more control over what gear your in, and increases clutch clamping pressure.
Not a must have for stage 1, but will complement it  :happy2:
Post by: K9 on May 28, 2015, 04:21:20 pm
when doing the stg1 custom map and rotortest, should i do a basic dsg reset after the map?
