All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: v1kkm on June 09, 2015, 09:28:01 am
Hello,
My golf appears to have issues with the driver side window. When i hit the switch to put it down/up it makes the noise for a split second but then nothing happens. I've checked the fuse and all ok. The passenger window is fine.
Any ideas what it could be? Where could i start in diagnosing this issue?
Thanks,
Vik
Anyone? :scared:
Got access to VCDS? Start with that.
Could be a relay, the switch itself, something jammed. Does the window drop if you hold the unlock button on the remote fob?
Other than that, take the door card off and take a look at anything obvious, the motor may have given up the ghost.
