All Things Mk5 => Mk5 General Area => Topic started by: samiul11 on June 09, 2015, 10:05:33 pm
Right guys im about to order a new PCV part number 06F 129 101 R and the pcv rubber gasket 06F 103 483 E.
My question is, is this all i need to change to the latest PCV? I've read up that a new check valve is needed too?
Any advice would be appreciated :drinking:
I was looking at this to replace mine, not sure now as the revised part doesn't match the one you listed.
http://www.psituning.com/product.php/21395/oem_pcv_breather_update_kit___2_0tfsi
Yes that and gasket is what i just replaced 2 minutes to replace it
So i wont need the breather pipe with the internal check valve?
i never replaced it unless it is physically damaged then i wouldn't no
I've read that the car runs rough if the latest pcv is installed but not the breather pipe? So confusing :rolleye:
i fitted it and car runs sweet i did do my diverter valve at same time
Anybody got the part number for the breather pipe?
This should help
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=1&grf=010380409&bf=10380&hgug=103&ug=03&parent_id=2335052
