All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Lyons on June 12, 2015, 03:54:17 pm
Title: Single Knock When Moving Off - gearbox/DMF
Post by: Lyons on June 12, 2015, 03:54:17 pm
Over the last few days my car has developed a knock when moving off from stationary. It doesn't happen every time, and is just a single knock. It's coming from the front. I don't believe it to be the steering as its when the car is straight, and jiggling the wheel doesn't induce it.
Any ideas as to what it may be?!
Title: Re: Single Knock When Moving Off
Post by: Redemption on June 12, 2015, 07:02:25 pm
Sub-Frame perhaps? Fairly common issue that can be solved by fitting these:-
www.awesomegti.com/ecs-subframe-spacer-plates-kit-mk5-mk6
Post by: Lyons on June 12, 2015, 07:36:27 pm
Thanks. I read about it but it seems to occur on lock too?
I suppose for the £ it would be safer to fit them anyway.
Post by: Redemption on June 12, 2015, 07:55:17 pm
That's a cheap option to start with. Chasing down knocks can quickly become an expensive ball-ache.
Post by: Lucas017 on June 12, 2015, 08:20:13 pm
I think I may have the same issue.
Does it appear to be louder some days than others?
Post by: GTI-Pirelli on June 12, 2015, 11:04:27 pm
I had side to side knock. Spirited driving caused it to knock on every corner and full lock in and out of parking spaces.
Sub-frame bolts solved it. :happy2:
Post by: Softishman on June 13, 2015, 08:00:20 am
Had this knocking myself when taking off ond stopping one knoch could be heard! Went for the big solution straight away because i read that the VW spacer kit not always worked...
This is the sh*t!:
http://www.tyrolsport.com/suspension/chassis/tyrolsport-deadset-rigid-subframe-collar-kit-for-all-mk5/6-jetta-gli-and-mk2-audi-tt/
Post by: Lyons on June 13, 2015, 10:02:55 am
That link says there's a TSB for it? Is that America only?
Post by: Softishman on June 13, 2015, 04:16:48 pm
Don't know that, i am in Sweden... :pomppomp:
Big spring service and update;
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww1.garaget.org%2Fgallery%2Fimages%2F1%2F481%2F481-7a45cf69f2048773f459e1a11b208838_large.jpg&hash=e0cd078962365cac96886599824bb08b08087a09)
Post by: bigeyd on June 14, 2015, 08:09:52 am
I have a knock but its a rarity so I will go for the cheaper kit and post results
Post by: Lyons on July 05, 2015, 06:52:12 am
More noises.
A fairly loud continuous knock that gets louder/faster the faster you go- slows right down when moving slowly. It pretty much disappears under heavy braking and accelerating, and is loudest when you lift your fit off the accelerator.
I should add that the car is booked in next week, so I'm not after an Internet diagnose as I appreciate it could be anything. Knowing nothing about mechanical bits, I'm just curious as to what it may be.
Post by: Johnsy on July 05, 2015, 09:31:38 am
More noises.
From  your description it could be a drive shaft! .
Interested not to hear if that cheaper bolt kit from awesome has solved the op original problem. I guess the cheaper option was upgrade to what VW had come up wit and the more expensive options is every bolt in the subframe
Johnsy
Post by: Lyons on July 15, 2015, 07:58:00 am
More noises.
Well, the mechanic looked at it last night and thinks it's a gearbox issue or the DMF. He's to remove it this weekend for a better look.
Is the DMF common to go in the Mk5?
