All Things Mk5 => Mk5 General Area => Topic started by: PM30S on June 15, 2015, 10:32:38 pm
Title: 57 reg Edition 30 can I install cruise control
Post by: PM30S on June 15, 2015, 10:32:38 pm
Hi all just bought a edition 30 on a 57 plate.
Can I just buy a cruise control stalk and fit it or not.
What's involved with getting the car to have this option fitted.
Many thanks
Title: Re: 57 reg Edition 30 can I install cruise control
Post by: bacillus on June 15, 2015, 10:56:01 pm
Once fitted you will need vcds to code it...
Post by: PM30S on June 15, 2015, 11:04:32 pm
Sorry to seem stuiped but what's vcds
Post by: Wash on June 15, 2015, 11:06:06 pm
As above, you just need to fit the stalk and get it coded. VCDS is the coding platform used on VWs to enable things like cruise control. Whereabouts are you from? Someone near you is bound to have it.
Post by: PM30S on June 15, 2015, 11:09:58 pm
North west London a place called Ruislip
Post by: Kam88 on June 15, 2015, 11:57:56 pm
I have VCDS but aint got a clue how to code it and i am based in Harefield if that helps  :signLOL:
Post by: RetroRaz on June 15, 2015, 11:58:42 pm
im in walthamstow, can fit and code for you.
Post by: Rossimac on June 16, 2015, 02:44:58 am
Do you have high-line clocks? There is a certain steering wheel controller needed as well.
Please read this thread to understand what you need - being a 57 plate you'll have the wire already going to the ECU, so that's one job down!
http://www.mk5golfgti.co.uk/forum/index.php?topic=35449.0 (http://www.mk5golfgti.co.uk/forum/index.php?topic=35449.0)
Also, look out for the newer shape of the cruise control stalk - version G.
Post by: PM30S on June 16, 2015, 06:36:56 am
Think I have Highline clocks with full screen also
Post by: omeydz on June 16, 2015, 07:27:45 am
Iv got a stock of cruise stalks if you need one mate.
Im away with work for the next week or so but can sort it once Im back.
Drop me a PM cheers  :happy2:
Post by: garrardrj on June 16, 2015, 08:09:07 am
You don't need highline clocks .....I had my ED30 fitted with Cruise and i didn't have them
Post by: Airz182 on June 16, 2015, 08:46:42 am
Is this info any different for a normal gti?
Post by: omeydz on June 16, 2015, 10:38:21 am
Apart from the odd midline module. All mk5s which have a trip computer be it midline or highline will support cruise control. Early 55 plates and earlier need an additional wire installed.
