All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Vwgtiking on June 21, 2015, 03:11:20 pm
Looking to get a wire from the engine bay to the cabin. Any help would great. I have the glove box out and nothing obvious.
If it's DSG there should be a grommet where the pedals are, or so I've been told.
No it's manual will have look on drivers side
On the passenger side behind the battery follow the main harness back this is an easy route through the firewall.
I followed this route the other day, removed the battery and battery tray, on the right of the abs pump is a rubber grommet, feed through a metal hanger wire and you will see if come out in the passenger footwell just behind the footwell light in top left corner, you will need to remove the foam above the passengers footwell to see it
This ^^^
Oh right. I didn't remove battery but I couldn't see anything obvious.
theres a rubber bung, has a few little rubber teets/ Nipples on it (Haha, nipples). Snip one of the nipples and feed your wire through
