All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: DanBoy on June 25, 2015, 11:25:45 am
Title: NQSBBK Brake pads moving in the calipers?
Post by: DanBoy on June 25, 2015, 11:25:45 am
Has anyone whose fitted the NQSBBK had any issues where the brake pads are moving in the caliper, if so how did you solve the issue??  :happy2:
Title: Re: NQSBBK Brake pads moving in the calipers?
Post by: rich83 on June 25, 2015, 11:32:15 am
You mean a knock when braking first time either forwards or backwards?
What pads are you using?
Post by: DanBoy on June 25, 2015, 11:36:52 am
Yea that's it, I've got Textar pads fitted on them at the moment, the garage has just fitted my set up and mentioned it to me.
Post by: rich83 on June 25, 2015, 11:40:54 am
TBH... is happens with some pads. My brother on his clio RS or Megane (cant remember which it happened on now) had the same problem with some pads.
Maybe try a different brand of pad.
Do the NQSBBK calipers have pad runners/guide? (cant remember their correct name)
Post by: DanBoy on June 25, 2015, 11:42:38 am
I've just checked on my Porsche look up and the Boxsters don't have the vibration plates that the 911's seem to have, I'll have to look into what other brands I can sort.
Post by: DanBoy on June 25, 2015, 05:53:06 pm
Just picked it up and tbh I can't hear the noise when you have the stereo on, but I'll probably uprate the discs and pads at a later date so hopefully it will sort the issue.
Post by: AIR_CHILLED on June 30, 2015, 09:40:12 pm
Hello Danboy,
What you need are anti-squeal / rattle shims for 36 & 40mm pistons.
You can find them on Eurocarparts and manually search under Porsche 911 3.4 litre, cira 90's build, they are approx £9 each and you'll need 4.
recently fitted these brakes., they are great!
