All Things Mk5 => Mk5 General Area => Topic started by: K9 on July 02, 2015, 07:20:18 pm
is this the correct panel that i need plus the surrounding?
5K0907044 BT for the panel?
car is a 2005 gti dsg with rcd510 fitted and heated seats
http://www.bold-sport.com/store/index.php?route=product/product&path=43_39_62&product_id=149
What does that automatic air recirculation function mean?
Writen with my fingers
I have a MK6 climatronic unit if you need.
PM Me :happy2:
PM Me :happy2:
@mvb12 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=4906) u got Pm bud! :happy2:
bump.
Anyone know if it Req. anything more then a new mk6 surrounding and a mk6 climatronic panel part. nr 5K0 907 044 ES
what about the pin swap from 16 to 20?
I have a oem rcd510 installed with a gateway part nr. 7N0 907 530AL will it display on the rcd510 when doing changes on the panel?
What about the heated seats as now it's 5 speed and new one is 3 speed? do i need to do any tweakings on VCDS with that or will it work just fine?
And what about VCDS basic settings etc?
Please help asap
You need to do the pin swap and code the panel. The coding is simple, just need to select the option with no sensor if you haven't fitted the AQS.
Then you need to reset the panel and check if your AC compressor starts and if your air recirculation works. You can also change the temperature from Fahrenheit to Celsius or vice-versa, depending on the settings that you need and that your panel is set. There are DIY online on how to retrofit the panel that explain all these questions. :wink:
I have heated seats too and they work without needing any other fiddling.
Great! Thanks you! Can you please link me the DIY where it explane about displaying on rcd510? Easy to do the pin swap?
http://www.mk5golfgti.co.uk/forum/index.php?topic=78320.0 (http://www.mk5golfgti.co.uk/forum/index.php?topic=78320.0)
http://forums.vwvortex.com/showthread.php?4938269-OEM-MKVI-Climatronic-on-a-MKV-on-a-RNS-510-Screen-installed (http://forums.vwvortex.com/showthread.php?4938269-OEM-MKVI-Climatronic-on-a-MKV-on-a-RNS-510-Screen-installed)
http://www.r32oc.com/topic/39962-golf-mk6-climatronic-in-a-golf-mk5-displaying-on-a-rns510/ (http://www.r32oc.com/topic/39962-golf-mk6-climatronic-in-a-golf-mk5-displaying-on-a-rns510/)
The RCD-510 displays the climatronic changes automatically, so you don't need to worry about that.
It was a friend of mine that did the pin swap (and the OPS sensors, the RVC, door warning lights, rear footwell lights, and Bluetooth loom update). For him it's very easy... :laugh:
Readed somewhere that pin 16 and 20 are not the same bases or pins. Or will 16 fit in 20 place if removed the whole pin? Or do i need to cut them both?
They're not the same size so need cutting.
Or getting a loom fron a golf mk6 where the pins are correct size and colour on the cables...
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww1.garaget.org%2Fgallery%2Fimages%2F1%2F481%2F481-983a13936f9806b386ac99a58a94e9e8_large.jpg&hash=208a59e3b0b2d2156753d9c8daed8d3099dbf3a1)
Did this to be able to switch back to mk5 clima easy!
The left connector is mk5 and right mk6.
Here is the cable you don'r re cinnect, black/green
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww1.garaget.org%2Fgallery%2Fimages%2F1%2F481%2F481-f1cbb1637c551ca6c7f4be8cfb420f25_large.jpg&hash=bd7eaf19cc7882567cac0c155080ad0f446eb267)
what do you men by mk6 loom? should i do like you if i want to switch back to mk5 climatronic when selling the car?
When i bought my mk6 clima panel i got the loom from tha car (mk6) aswell, i took the cable with rightcolour and right type oc vonnector and soldered it the my mk5 loom as pictured! Now it is really easy ti switch back again if tou want to!
I'm not getting the loom so whats the best i can do?
Then remove both pins and cut the black/green off (you don't use it anyway) snd solder it to the other red/yellow cable.
@Softishman (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=9358) whats the best way to remove the pins from the connectors without damaging anything?
i cant find a trim for the mk6 unit :surprised:
I bought a cheap kit frim ebay, vw pin removal tool kit or something like that...
The trim piece i bought from vw dealer, if you google mk6 clima on mk5 you will find some old threads that tells witch art nr you need!!
Ebay item nr:
252004726747
You could use this tool
http://www.ebay.co.uk/itm/Laser-3932-Terminal-Tool-/311171376685?pt=LH_DefaultDomain_3&hash=item487342662d
Great will order it tomorrow! Can these be found in local electric stores?
Possibly in Andrew Pages or another motor factors but they will be more expensive than eBay!
So 3932 tool is the correct to remove one or both pins?
I've not got one I had to buy a kit but It should do the job - watch a few YouTube videos to help you out https://m.youtube.com/watch?v=1OQevVIglTE
Guess i will order the tool. I don't want to do any damage to it if i will re-install the mk5 unit sometimes.
You want to go to VW and ask for a Jetta with climatronic surround. They are order in but £12!! I didn't like the mk6 in mine so got rid.
Why jetta and not golf mk6 surround?
The mk6 surround is a different shape to the mk5, it starts under the radio and only covers the heater controls. The mk5 surround goes up to the top of the radio almost. Check out some pictures you'll see the difference. The Jetta surround is the shape you need. If you search for old posts on here and elsewhere on the net, it has been covered hundreds of times before and someone even shares the PN for the Jetta surround. I gave the receipt to the new owner of mine so don't have it to hand.
Ain't the golf mk6 climatronic surround same as jetta?
@K9 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=6852) Com'on man! You were told they're different. Do a bit of research before making questions and listen to the people trying to help you. :wink:
You can easily search a picture of a Golf mk6 dashboard and see that the surround is different. You need the Jetta mk6 surround. Done!
I allways thought that it should be the mk6 surround
Is this corecct part nr 1KD 858 069 1QB?
It's 1K0 858 069 N 1QB. You just missed the N (revision letter). :happy2:
Any ideas what dealers take for one nowdays?
Cant find it on ebay :o
I bought one from VW 2 years ago for my GT Sport and it cost me then 43,53 €.
For the Ed. 30 I bought the pack (climatronic panel and Jetta mk6 surround) from Bold Sport.
Will go down to vw and ask tomorrow.
I paid £17 for mine earlier in the year but they had to order it in.
