All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: fletch- on July 09, 2015, 06:45:44 pm
Hi guys, recently brought my golf gt tdi and was disappointed with a lack of aux! So I brought a RCD510 DAB. All is working fine and I love how much better the sound is!! However, it has a Bluetooth button, how do I and what do I need to buy for this to work? Many thanks
You'll need a Bluetooth interface module, something like this
http://www.ebay.co.uk/itm/OEM-Bluetooth-Interface-Module-9W2-FOR-VW-Volkswagen-RCD510-1K8-035-730-D-/310782526885?pt=LH_DefaultDomain_3&hash=item485c1505a5
That might not be the exact one you need cause I'm no expert but it says it is compatible with the rcd510
I think that module is old now, hence the lower price. Look for a 7P6 module. I think there are some for sale in the For Sale section of this forum. :wink:
Lovely thanks. Do these plug in to the harness then? And do they need coding to work?
They have a loom that connect to the rear Quadlock connector, yes.
They need coding but it's easy. Mine worked fine before I coded it but had errors with VCDS that were solved after coding. :happy2:
Cool that's great. I'm new here, do I have to have a certain amount of posts before I can PM? I want to get in touch with Eddie-nl about a dab aerial and this Bluetooth module? Thanks!
Yes, you need to have 10 posts, I think. Read the rules to get to know the forum. :wink:
get a 7p6. it will need coding and you may need a canbus upgrade as well (as I found out) as the 7p6 may not be compatible with your old canbus.
A RCD-510 already required a newer CANBUS. :wink:
Even a 1K0 907 530 L is compatible with a 7P6 module. :smiley:
Lovely thanks a lot guys. Had vxr's for years and they were so simple conspired to my golf haha will take some getting used to
Vxr's?
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fab31%2Frobmcclel%2Ftumblr_mus4scqkof1shxe70o1_500_zpslb6ct4uo.gif&hash=5b49190dc8233c977c5ecdbd04c66230502c6833)
:signLOL:
A corsa and Astra Vxr :sad1:
i have a late version K which has no battery drain so im using that but it does not allow coding of the 7p6.
K versions are only good enough for the battery drainage of RCD/RNS-510, not good enough for RNS-315 and newer BT modules. Get a newer CAN, L, Q, etc...
Mine is a late 58 plate built in 2009 so I should be ok with the canbus gateway shouldn't I? It's been in 4 days now and battery hasn't died so :D
I planned to but its working fine with rcd510 and 7p6 for now. no drain. I can make calls not sure if Bluetooth music works as not tried it. just cant code it that's all.
Yeah, you're fine. Your CAN should be a Q version like my GT Sport. :happy2:
Like I said, mine worked fine before getting it coded. The coding just made the VCDS error go away. :grin:
Lovely thanks for your help guys! :happy2:
Reviving this thread if poss, I have a 08 golf edition 30, fitted rcd510 dab works fine, now fitted a 7p6 Bluetooth module which also works but no1 can hear me! I have now got vagcom which is saying I need to code it so coming up as a error , any1 done this or is there a tutorial in which I can't find! New to vagcom and don't want to make things worse haha
Did you get the loom with the bluetooth module? The mic might need the wiring checked...
Yes pal I got the loom as well. Checked the wiring all ok. Bought another mic before I realised to plug it in vagcom. Tried the new one and still not working
Check this picture to see if it helps you:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fmm475%2FShoduchi%2FBluetooth_Mic_wiring.jpg&hash=6a204ef235e1d7ca9dad388f8239f9ccbcaec103)
Not sure how your loom is making the connections.
May help, will crack on with that over next few days now am back at work. Many thanks for your help
Fletch I have a 7p6 Bluetooth module for sale, could've posted it with the grills!
:sad1: I didn't know mate!! Will be in touch then next payday as I'm still in need of one :happy2:
