All Things Mk5 => Mk5 General Area => Topic started by: Daled0111 on July 11, 2015, 06:12:16 pm
Title: Radiator fan pulsating
Post by: Daled0111 on July 11, 2015, 06:12:16 pm
The fan is pulsating when I lock my car anybody got any idears
Title: Re: Radiator fan pulsating
Post by: doylebros on July 11, 2015, 07:00:18 pm
Get it scanned with VCDS  http://www.mk5golfgti.co.uk/forum/index.php/topic,88875.0.html and see what it shows as I've had a few strange things happen when this item fails
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=1&grf=012130474&bf=12130&hgug=121&ug=21&parent_id=2337093&detail_id=2337133
Post by: Daled0111 on July 12, 2015, 10:41:41 am
Have scanned it at work with our snap on top of the range scanner but there are no codes stored
Post by: doylebros on July 12, 2015, 10:57:43 am
With the engine running and the aircon on low are both fans running?
Post by: Daled0111 on July 12, 2015, 03:28:54 pm
yh think so
Post by: Daled0111 on July 12, 2015, 09:27:03 pm
Yes both fans kick in when turn aircon on and then they go off when I turn it off
Post by: doylebros on July 12, 2015, 09:34:29 pm
Assuming there's plenty coolant and your thermostat and inline stats are ok I would look at the auxiliary coolant pump
http://www.pelicanparts.com/techarticles/Volkswagen_Golf_GTI_Mk_V/33-WATER-Electric_Coolant_Pump_Replacement/33-WATER-Electric_Coolant_Pump_Replacement.htm
With VCDS you can run and test the pump in output test etc and check system values for temperatures.
Post by: Daled0111 on July 12, 2015, 11:48:15 pm
Just done a battery test with a computer from work and it says bad and replace
Would this have anything to do with it
