All Things Mk5 => Mk5 General Area => Topic started by: mikec on July 13, 2015, 09:23:01 pm
Title: PCV Delete - Forge, Revo etc
Post by: mikec on July 13, 2015, 09:23:01 pm
Hey all,
Just wondering if the PCV deletes are worth it? Is there a benefit to them that is proven?
Im thinking of removing mine and replacing with the delete from either Forge or Revo.
Title: Re: PCV Delete - Forge, Revo etc
Post by: Orc on July 13, 2015, 10:37:20 pm
No No No there not proper delete kits, goto R tech and get there new designed COMPLETE kit. Limited Stock only. :happy2:
Post by: th3_f15t on July 14, 2015, 05:04:10 pm
Don't remove the stock PCV, just leave it alone. Unless you go for a proper catch can system, it's more trouble than it's worth using delete kits, seen a lot of cases on here of engine issues due to excessive pressure inside the block. Do a search on PCV deletes and you'll dig them up.
Post by: Orc on July 14, 2015, 09:12:06 pm
Thats because they haven't developed the proper delete kit, Niki has take a look at his latest product at RTech Developments
