All Things Mk5 => Mk5 General Area => Topic started by: Sav213 on July 17, 2015, 09:11:35 pm
Title: DSG. Rev issue stays at 2000rpm rather than dropping down below 1000rpm???
Post by: Sav213 on July 17, 2015, 09:11:35 pm
New problem tonight!
Start the car up and it idel's normal (under 1000rpm) but if i press the throttle and rev up, it drops back down and stops at 2000rpm! Another little tough then it drops back to normal
Like theres a clutch issue or something. Also the exhaust gas warning lamp come on for the first time!
Any one have any ideas?
Title: Re: DSG. Rev issue stays at 2000rpm rather than dropping down below 1000rpm???
Post by: NoelRev on July 21, 2015, 09:58:45 am
Does the rpm rise and drop without throttle response? I would check the PCV as a failed one can cause lumpy idles
