All Things Mk5 => Mk5 General Area => Topic started by: irish_ram on July 19, 2015, 04:52:43 pm
Title: Short Term Intake Solution
Post by: irish_ram on July 19, 2015, 04:52:43 pm
Hi All,
The car has been sounding a bit weird the last few days, so on more inspection I found the standard intake was cracked right at the front of the airbox part which attaches behind the grill. I am going to replace it or get an aftermarket Intake however in the meantime I have fitted the below solution as a short terms fix which has got rid of the weird noise.
I want to confirm this short terms solution(say no more than a couple of weeks) is okay to run on until I fit a replacement OEM intake or aftermarket one. I gave it a test drive in both D and S and gave it some rev and was totally fine. Actually sound a bit louder and better when putting my foot down.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fpp78%2FSuper_Ram%2FFullSizeRender.jpg&hash=e219d9643cdcdcb22544517faa6b75d6678305c9)
Title: Re: Short Term Intake Solution
Post by: th3_f15t on July 19, 2015, 10:52:53 pm
This is a similar solution to the BMC CDA intake, so it'll be fine to run for as long as you need. :happy2:
