All Things Mk5 => Mk5 General Area => Topic started by: irish_ram on July 21, 2015, 07:47:27 pm
Title: Noise from Engine
Post by: irish_ram on July 21, 2015, 07:47:27 pm
Hi All,
I noticed a noise coming from the engine bay the other day so recorded it to see if anyone has an idea if this is a fault and if so what it could be
http://vid399.photobucket.com/albums/pp78/Super_Ram/Engine%20Noise.mp4
Title: Re: Noise from Engine
Post by: ephemeross on July 21, 2015, 08:16:43 pm
Sounds normal to me, not sure if I'm missing which sound you're referring to though?
Post by: irish_ram on July 21, 2015, 08:23:18 pm
That is what I wanted to hear, I think it is the main sound of the belt going round I presume but was not sure if this was a bit noisy suggesting a fault
Post by: ephemeross on July 21, 2015, 08:50:02 pm
Ah, then yeah mine sounds the same (170 TDI) before and after belt kit was done.
Post by: RedGolfDom on July 21, 2015, 09:51:40 pm
If you are worried pour some water on where the belt is and see if the noise (if there's one we can't hear on the video ) stops. If so it will be a pully,  belt or water pump. Did it for my tsi and ended up being the water pump
Post by: JUNNYAK47 on July 21, 2015, 10:14:22 pm
Can you hear the ticking insife the car?  If so its a loose fanbelt tensioner.  Solved the problem on mine
Post by: irish_ram on July 22, 2015, 12:13:36 pm
Thanks chaps, I am just hoping it is my mind playing tricks on me and there is nothing wrong but will try the water trick and listen for the ticking to find out if there is any issues.
Post by: CarlW on July 22, 2015, 02:42:20 pm
i have the same ticking noise on my 2005 GTi, as far as I'm aware its standard for it to sound like this although its not nice or appealing.. it is what it is
Post by: MizGTi on July 23, 2015, 02:11:17 am
Sounds normal. Read up on this as i was concerned. Some say it is the noisy injectors. Nothing to worry about i was told
