All Things Mk5 => Mk5 General Area => Topic started by: david25 on August 08, 2015, 05:51:31 pm
Title: Wind noise from drivers door - recommendations please FIXED
Post by: david25 on August 08, 2015, 05:51:31 pm
Hello everyone, I am gradually fixing the basics with my new 2006 black GTI (DV / PCV etc).
One of the more troublesome problems is wind noise from the drivers door (top corner near B pillar) at speeds over 50mph.
I don't think its the window seal on the felt seal, pressing the top corner "outwards" makes no difference, when I got the car all the seals were white from age, although no visible tears.
So, should I start with the inner seal attached to the body or the seal on the door?
Is the seal on the door stuck on? If so, it looks beyond my DIY skills.
Anyone had this problem? How did you fix it?
Title: Re: Wind noise from drivers door - recommendations please
Post by: Redemption on August 08, 2015, 06:32:17 pm
Try some Einszett Gummi Pflege on all the seals and see if that helps.
Post by: david25 on August 08, 2015, 06:49:30 pm
Thanks that is first I tried, I had some from my old GTI, it got rid of the white marks and made the rubber look in better condition. But the noise is still there.
Post by: petesimcock on August 09, 2015, 07:30:25 am
I have a similar problem but mine happens at any speed and even when stationary. It only happens when the interior fans are on. Very strange problem and a highly annoying noise.
Post by: david25 on August 09, 2015, 09:55:05 am
I am having the inner seal replaced next week, my independent specialist stated the inner seal is not glued, so its easier to remove and replace.
Will update shortly.
Post by: david25 on August 21, 2015, 05:44:19 pm
Hello, had the inner seal replaced today. Unfortunately, wind noise is still present.
Garage said the noise could be "channeled" through another part of the door to the top corner, they want to try and tape the door and see if that fixes it.
Then slowly remove tape to find the area.
Title: Re: Wind noise from drivers door - recommendations please FIXED
Post by: david25 on August 25, 2015, 05:53:04 pm
Right, after replacing the inner door seal with no fix, the garage suggested a taping all the seals shut and seeing if it could be isolated this way.
After another close visual inspection by myself, I found a very small hole between the rubber seal and B pillar trim (near the BOTTOM of the red arrow) I will upload my own pic when its not raining.
I filled this in with Blu Tack and the noise has gone!
(https://lx3.smugmug.com/photos/i-B3RBNC7/0/M/i-B3RBNC7-M.jpg)
Post by: Rossimac on August 26, 2015, 01:49:19 am
Good job. What's the permanent solution?
Post by: GTIEagles on August 26, 2015, 09:28:54 am
New door seal I would say?
Post by: david25 on August 26, 2015, 06:50:44 pm
I don't know, you can't get black Blu tack! Any suggestions?
Post by: david25 on August 26, 2015, 06:51:17 pm
No, have a look at the pic, perhaps a new B pillar trim and the rubber seals around it?
Post by: Andy on August 26, 2015, 07:16:24 pm
Get new b pillow trims and try it
Post by: dazza on August 26, 2015, 07:29:30 pm
Use the black backing off some sound deadening.
Post by: Matto on August 26, 2015, 11:42:57 pm
I suffer with the same wind noise issue and changed to gloss black pillars a while ago but it was still the same.
@david25 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=3234) How about trying some black Sugru? I reckon that would be perfect for the job.
Post by: david25 on August 27, 2015, 05:47:59 pm
Thanks, never heard of this stuff, but know I know!
Check if you have the gaps, it might help you as well.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fobjectandline.co.uk%2Fmedia%2Fcatalog%2Fproduct%2Fcache%2F1%2Fimage%2F600x%2F9df78eab33525d08d6e5fb8d27136e95%2Fb%2Fu%2Fbutton_b3.jpg&hash=087e1823cabf67afeac52d269fb10dbcc9092bf8)
