All Things Mk5 => Mk5 General Area => Topic started by: e4n94 on May 14, 2019, 07:26:24 PM
Title: That time of year air con time
Post by: e4n94 on May 14, 2019, 07:26:24 PM
I purchased my ed30 last august and I never really used the air con until today I went to use it and nothing. The ac button lights up the revs change when turning the ac on and off the fans don't come on.
I checked the codes and had 00898 control circuit ac compressor open circuit
I Then cleared the code check the pump connection all ok and still nothing
Is this a simple Regas or should the fans work
Title: Re: That time of year air con time
Post by: Lucky ducky on May 14, 2019, 08:11:38 PM
Ha! join the club I'm getting nothing not a geek not a fan when I turn it on
did a scan and got  " refrigerant pressure lower limit not reached" code 00229 status static... Dunno what's up with that
Post by: e4n94 on May 14, 2019, 08:18:23 PM
Sounds like it's low on gas that does
Post by: bobby_fodge on May 14, 2019, 08:19:43 PM
Go to ATS, they will recharge your aircon, if the recharge isn't successful you don't get charged.
Post by: Lucky ducky on May 14, 2019, 08:31:39 PM
Thanks guys yeah hope it's just a regas
Post by: richtung on May 14, 2019, 09:28:41 PM
If you are going to ATS - get the Groupon offer https://www.groupon.co.uk/deals/ats-euromaster-ltd-20 (https://www.groupon.co.uk/deals/ats-euromaster-ltd-20)
If your budget allows, fork out for the regass and antibacterial treatment (£44.99)
Rich
Post by: amanda on May 15, 2019, 01:12:11 PM
I had mine done at dealers for £49 as I know mine only needs a re gas as radiator and refrigeration unit were replaced about 3 yrs ago ..........
Post by: Pudding on May 15, 2019, 02:12:22 PM
http://wiki.ross-tech.com/wiki/index.php/00898
Post by: amanda on May 15, 2019, 02:18:54 PM
Ohhhh pudding........straight to the point as always😱🤣  :booty:
Replacement if needed won’t be cheap as I found out!!!!!!
