Author Topic: ED30 overboosting and feels like clutch is slipping  (Read 6674 times)
Offline STV4R
« on: August 26, 2015, 06:50:29 pm »
I switched to APR remap few weeks ago and since doing so have run into a few problems. First thing was the stage 2 map, (actual) fuel rail pressure was all over the place. Requesting 119 and getting like 78/80 then jumping up and back down. Took in to tuner and said it was the HPFP so i upgarded that to the APR HPFP and he updated my software to go with it. Since doing that im now getting overboost from around the 3k rpm right to the redline and no faults in VCDS. Also feels like my DSG is slipping, put my toe down from aroung the 3k rpm mark and the revs jump up by about 300/400rpm. These problems have only started since going from revo stage 1 to APR. Ive included a few logs if some of you experts can have a look at them and let me know what you think please. Garage is fully booked untill next friday so would like to try and figure out whats going on.
And my mods are, Evoms CAI, Scorpion 3" DP and Decat, APR HPFP, R8 coil packs and RS4 Fuel return valve.
Stage 2 log with fuel rail issue so upgarded the hpfp
these 2 logs are after the hpfp was fitted with stage 2+ file
« Last Edit: August 27, 2015, 08:38:37 pm by STV4R »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=s9jpb3vt2eqqqgop96f5uhb4jh&/topic,90967.msg917089.html#msg917089
Re: ED30 overboosting and feels like clutch is slipping
« Reply #1 on: August 26, 2015, 06:58:32 pm »
Try posting up the entire log (unedited)
Click Logging Icon
Paste vcds code.
You also need to write something outside the logging tag or it will say post is empty.
« Last Edit: August 26, 2015, 07:05:42 pm by dazza »
05 | Tornado Red | DSG
Offline v4rley
  • -Receive: 104
« Reply #2 on: August 26, 2015, 07:50:07 pm »
Click Logging Icon
Paste vcds code.
@dazza what is the vcds code as I tried this the other week and was unsure what it is or where to find it  :stupid:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #3 on: August 26, 2015, 08:02:05 pm »
Open the csv log file from vagcom with notepad/text editor and copy and paste all of the code.
« Last Edit: August 26, 2015, 08:08:46 pm by dazza »
Offline STV4R
« Reply #4 on: August 27, 2015, 03:17:04 pm »
Click Logging Icon
Paste vcds code.
Cant get it to work mate
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #5 on: August 27, 2015, 04:00:56 pm »
post the log here and i will try it
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #7 on: August 27, 2015, 04:26:44 pm »
« Last Edit: August 27, 2015, 04:32:47 pm by dazza »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #8 on: August 27, 2015, 04:34:12 pm »
LOG 1
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #9 on: August 27, 2015, 04:34:52 pm »
Log 2
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #10 on: August 27, 2015, 04:35:59 pm »
Hope this helps mate.
Were you logging in turbo mode?
« Last Edit: August 27, 2015, 04:43:55 pm by dazza »
Offline STV4R
« Reply #11 on: August 27, 2015, 06:45:39 pm »
2 logs are without turbo mode on. i forgot to turn it on
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #12 on: August 27, 2015, 06:55:07 pm »
Major drop in fuel pressure on the one log
Offline STV4R
« Reply #13 on: August 27, 2015, 08:36:45 pm »
yea that was when i got the APR stage 2 put on and tuner said it was the HPFP so i upraded it to APR HPFP and got the map updated to suit it. Then thats when started to get the overboost issue and the feeling of clutch slipping.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #14 on: August 27, 2015, 08:50:57 pm »
Should have read opening post properly. APR2+ gives huge boost, more than VCDS will show in specified. Logs look fine to me. The extra boost & torque from going 2+ sounds like its too much for the DSG. Has it been serviced? Tried Tried a reset with VCDS? Having DSG mapped can increase clamping pressure which would help
